Hello,
I am trying to make faster the code fo reading a HX711.
There is this line that goes:
result |= digitalRead(A0) << i;
If I change it for:
result |= ((PIOA->PIO_PDSR & (0x1u << dat_pin)) ?1:0) << i;
I don't get the same result.
Do you know why?
All the code where you can see the transformations (old are commented, new use registers):
if(!(PIOA->PIO_PDSR & (0x1u << dat_pin))) {//READ
//if(!digitalRead(A0)) {
int result = 0;
//Las lecturas no pueden ser interrumpidas
//noInterrupts(); //quizás poner prioridad top.
//PIOB->PIO_SODR = PIO_PB17;//A8 HIGH
//noInterrupts();
for (int i = 23; i >= 0; --i) {
PIOA->PIO_SODR = 1u << clk_pin;//WRITE HIGH
//digitalWrite(A1, HIGH);
result |= ((PIOA->PIO_PDSR & (0x1u << dat_pin)) ?1:0) << i; //READ Final result = 49250.
//result |= digitalRead(A0) << i; //READ Final result = 98500.
PIOA->PIO_CODR = 1u << clk_pin;//WRITE LOW
//digitalWrite(A1, LOW);
//Ciclo extra que determina la ganancia de la iguiente lectura: 1 ciclo = 128.
//interrupts();
//Volvemos a habilitar interrupts.
//interrupts();
//Rellena con unos o ceros por signo.
result |= (result & 1UL << 23 ? 0xFFUL : 0x00UL) << 24;
Serial.println(result);
IMPORTANT: the result I get with the line using the register is half the result if I use digitalRead. The other lines I can switch between using digitalRead/Writes and registers without problem.
Anyone know the difference between the 2 lines?
