Due Scheduler Delaymicros()
Hi Due users, I'm fairly new to arduino and programming so pardon any super newbie questions.
I'm trying to run two stepper motors at varying speeds using an Arduino due + scheduler.h.
The problem occurs using delay microseconds where 1 motor runs then the other freezes while using a regular delay command has both motors running.
I've found two semi helpful threads so far found here:
These threads are both 2-4 years old however so I'm bringing the question up again. It seems there are solutions in these threads, I'm curious where I should be inserting these fixes ?
What header/c files should I be adding this code to ?
Any extra steps to get the code to function?
Thank you for your help
I am having the same exact issue, I'm assuming you found a solution by now. If so, what was it?
