Due support for AVR (atmel) libraries
I am currently using the Arduino Due, a Macbook pro, and have purchased a BLE shield from Red Bear labs (http://redbearlab.com/bleshield/)
I have installed their libraries, however I am having problems running their example projects. The Arduino IDE says that <avr/sleep.h> could not be found:
In file included from BLEControllerSketch.ino:16:0:
/Users/shazkam/Documents/Arduino/libraries/RBL_nRF8001/RBL_nRF8001.h:21:23: fatal error: avr/sleep.h: No such file or directory
 #include <avr/sleep.h>
compilation terminated.
However, the avr library and the sleep.h file are included with the arduino software as can be seen from my screen shot: http://i.imgur.com/tecWrNA.png
Most of the example code that I am trying to run can be found below (I could not put all of it as characters here are limited)
#include <Servo.h>
#include <SPI.h>
#include <boards.h>
#include <RBL_nRF8001.h>
#include <services.h>
#include "Boards.h"
#define PROTOCOL_MAJOR_VERSION   0 //
#define PROTOCOL_MINOR_VERSION   0 //
#define PROTOCOL_BUGFIX_VERSION  2 // bugfix
#define PIN_CAPABILITY_NONE      0x00
#define PIN_CAPABILITY_DIGITAL   0x01
#define PIN_CAPABILITY_ANALOG    0x02
#define PIN_CAPABILITY_PWM       0x04
#define PIN_CAPABILITY_SERVO     0x08
#define PIN_CAPABILITY_I2C       0x10
// pin modes
#define ANALOG                  0x02 // analog pin in analogInput mode
#define PWM                     0x03 // digital pin in PWM output mode
#define SERVO                   0x04 // digital pin in Servo output mode
byte pin_mode[TOTAL_PINS];
byte pin_state[TOTAL_PINS];
byte pin_pwm[TOTAL_PINS];
byte pin_servo[TOTAL_PINS];
Servo servos[MAX_SERVOS];
  Serial.begin(57600);
  Serial.println("BLE Arduino Slave");
  /* Default all to digital input */
  for (int pin = 0; pin < TOTAL_PINS; pin++)
    // Set pin to input with internal pull up
    pinMode(pin, INPUT);
    digitalWrite(pin, HIGH);
    // Save pin mode and state
    pin_mode[pin] = INPUT;
    pin_state[pin] = LOW;
  // Set your BLE Shield name here, max. length 10
  //ble_set_name("My Name");
  // Init. and start BLE library.
  ble_begin();
static byte buf_len = 0;
byte reportPinAnalogData()
  if (!ble_connected())
    return 0;
  static byte pin = 0;
  byte report = 0;
  if (!IS_PIN_DIGITAL(pin))
    pin++;
    if (pin >= TOTAL_PINS)
      pin = 0;
    return 0;
  if (pin_mode[pin] == ANALOG)
    uint16_t value = analogRead(pin);
    byte value_lo = value;
    byte value_hi = value>>8;
    byte mode = pin_mode[pin];
    mode = (value_hi << 4) | mode;
    byte buf[] = {'G', pin, mode, value_lo};
    ble_write_string(buf, 4);
  pin++;
    pin = 0;
  return report;
byte queryDone = false;
  while(ble_available())
    byte cmd;
    cmd = ble_read();
    Serial.write(cmd);
    // Parse data here
    switch (cmd)
      case 'V': // query protocol version
          byte buf[] = {'V', 0x00, 0x00, 0x01};
      case 'C': // query board total pin count
          byte buf[2];
          buf[0] = 'C';
          buf[1] = TOTAL_PINS;
          ble_write_string(buf, 2);
      case 'M': // query pin mode
          byte pin = ble_read();
          byte buf[] = {'M', pin, pin_mode[pin]}; // report pin mode
          ble_write_string(buf, 3);
      case 'S': // set pin mode
          byte mode = ble_read();
          if (IS_PIN_SERVO(pin) && mode != SERVO && servos[PIN_TO_SERVO(pin)].attached())
            servos[PIN_TO_SERVO(pin)].detach();
          /* ToDo: check the mode is in its capability or not */
          /* assume always ok */
          if (mode != pin_mode[pin])
            pinMode(pin, mode);
            pin_mode[pin] = mode;
            if (mode == OUTPUT)
              digitalWrite(pin, LOW);
            else if (mode == INPUT)
              pin_state[pin] = HIGH;
            else if (mode == ANALOG)
              if (IS_PIN_ANALOG(pin)) {
                if (IS_PIN_DIGITAL(pin)) {
                  pinMode(PIN_TO_DIGITAL(pin), LOW);
            else if (mode == PWM)
              if (IS_PIN_PWM(pin))
                pinMode(PIN_TO_PWM(pin), OUTPUT);
                analogWrite(PIN_TO_PWM(pin), 0);
                pin_pwm[pin] = 0;
                pin_mode[pin] = PWM;
            else if (mode == SERVO)
              if (IS_PIN_SERVO(pin))
                pin_servo[pin] = 0;
                pin_mode[pin] = SERVO;
                if (!servos[PIN_TO_SERVO(pin)].attached())
                  servos[PIN_TO_SERVO(pin)].attach(PIN_TO_DIGITAL(pin));
  //          reportPinAnalogData(pin);
          if ( (mode == INPUT) || (mode == OUTPUT) )
            reportPinDigitalData(pin);
            reportPinPWMData(pin);
            reportPinServoData(pin);
      case 'A': // query all pin status
          reportPinCapability(pin);
          if ( (pin_mode[pin] == INPUT) || (pin_mode[pin] == OUTPUT) )
          else if (pin_mode[pin] == PWM)
          else if (pin_mode[pin] == SERVO)
        queryDone = true;
          uint8_t str[] = "ABC";
          sendCustomData(str, 3);
      case 'P':
      case 'Z':
          byte len = ble_read();
          byte buf[len];
          for (int i=0;i<len;i++)
            buf[i] = ble_read();
          Serial.println("->");
          Serial.print("Received: ");
          Serial.print(len);
          Serial.println(" byte(s)");
          Serial.print(" Hex: ");
            Serial.print(buf[i], HEX);
    // send out any outstanding data
    ble_do_events();
    buf_len = 0;
    return; // only do this task in this loop
  if (Serial.available())
    byte d = 'Z';
    ble_write(d);
    delay(5);
    while(Serial.available())
      d = Serial.read();
      ble_write(d);
    ble_do_events();
    buf_len = 0;
    return;
  // No input data, no commands, process analog data
    queryDone = false; // reset query state
  if (queryDone) // only report data after the query state
    byte input_data_pending = reportDigitalInput();
    if (input_data_pending)
      ble_do_events();
      buf_len = 0;
    reportPinAnalogData();
    ble_do_events();
    buf_len = 0;
    return;
  ble_do_events();
  buf_len = 0;
The file that is throwing the error is:
#ifndef  _RBL_NRF8001_H
#define _RBL_NRF8001_H
#include <boards.h>
#include <lib_aci.h>
#include <aci_setup.h>
#include <SPI.h>
#include <avr/interrupt.h>
/* Put the nRF8001 setup in the RAM of the nRF8001.*/
#include "RBL_services.h"
/* Include the services_lock.h to put the setup in the OTP memory of the nRF8001.
This would mean that the setup cannot be changed once put in.
However this removes the need to do the setup of the nRF8001 on every reset.*/
#if defined(BLEND_MICRO)
#define DEFAULT_REQN    6
#define DEFAULT_RDYN    7
#else
#define DEFAULT_REQN    9
#define DEFAULT_RDYN    8
#endif
void ble_begin();
void ble_set_name(char *name);
void ble_write(unsigned char data);
void ble_write_bytes(unsigned char *data, unsigned char len);
void ble_do_events();
int ble_read();
unsigned char ble_available();
unsigned char ble_connected(void);
void ble_set_pins(uint8_t reqn, uint8_t rdyn);
unsigned char ble_busy();
#endif
I cannot seem to enable the compiler to the include the sleep.h file which is inside the Arduino app. Robtillaart has told me that the problem seems to be that the Due is an ARM processor and it has no support for AVR (atmel) libraries. I am wondering if there is a work around or someway that I can run my code. Any help on this would be greatly appreciated.
No, you can not use avr libraries on an arm processor. What you can do to solve this problem, is finding out what function the code uses from the avr library, and make an equivalent function that does work on the due.
http://asf.atmel.com/docs/latest/sam3x/html/group__sam__drivers__pmc__group.html
http://asf.atmel.com/docs/latest/sam3x/html/group__sam__drivers__pmc__group.html#ga3771318f6dcf951222b739363e8960ba
It's more complicated on ARM, dig into datasheet for datails.
