The code below is intended to use the TC0, channel 1 timer in capture mode with a MCK/2 (42MHz) clock. A frequency is generated on pin 7 (PWM) of 50Hz. A jumper is connected between pin 7 and A7 (TIOA1). I've check the frequency and duty cycle of the PWM with an oscilloscope and it is correct.
On the rising edge of TIOA1 the ISR will save the TC0_RA1 register. On the falling edge the ISR will save the TC0_RB1 register. The ISR also sets a flag to indicate to loop() that a new value is available and loop() clears the flag once the captured data is read from the variable.
The ISR is being fired but the data read from TC0_RA1 and TC0_RB1 are not correct. The ISR seems to be executing continuously. If I disconnect the jumper the ISR quits firing as it should. Don't quit understand this yet.
I'm hoping someone can help me out with what I'm doing wrong or leaving out of the code.
I've done a lot of research on this and have read the Atmel datasheet on this processor. The code is very close but still no cigar.
Any help will be greatly appreciated.
Thanks in advance!
// variables used within the ISR
volatile unsigned long CaptureCountA=0, CaptureCountB, TimerCount=0;
volatile bool CaptureFlag=0;
// define bit numbers for the TC registers we are using
const byte COVFS=0, LOVRS=1, CPAS=2, CPBS=3, CPCS=4, LDRAS=5, LDRBS=6, ETRGS=7,
CLKSTA=16, MTIOA=17, MTIOB= 18; // TC_IERx and TC_SRx bits
const byte CLKEN=0, CLKDIS=1, WSTRG=2; // TC_CCRx bits
const byte TCCLKS=0, CLKI=3, BURST=4, LDBSTOP=6, LDBDIS=7, ETRGEDG=8, ABETRG=10,
CPCTRG=14, WAVE=15, LDRA=16, LDRB=18; // TC_CMRx bits
Serial.begin(9600); // initilize serial port to 9600 baud
while (!Serial) { } // wait for serial port to initialize
// setup TC0 bank, channel 1 (TC1) for input capture mode w/clk of 42MHz
pmc_enable_periph_clk (ID_TC0) ; // enable clock the TC0 channeL 0, to access TC0_WPMR
REG_TC0_WPMR = 0x54494D00; //WPKEY, disable
pmc_set_writeprotect(false); // enable write to TC registers
pmc_enable_periph_clk (ID_TC1) ; // enable clock the TC0 channel 1
REG_TC0_CCR1 = 0; // clear all bits in TC0_CCR1
REG_TC0_CCR1 = 1 << CLKEN; // enable clock
REG_TC0_CMR1 = 0; // capture mode, mclk/2, clk on rising edge
// burst disabled, clk not disabled when loading RA/RB
// capture mode
REG_TC0_CMR1=((3 << ETRGEDG) | // trigger on both edges of trigger input
(1 << ABETRG) | // TIOA is used as the external trigger
(1 << LDRA) | // load RA on rising edge of trigger input
(2 << LDRB)); // load RB on falling edge of trigger input
REG_TC0_IER1 = 0; // disable TC1 interrupts
REG_TC0_IER1 = ((1 << LDRAS) | (1 << LDRBS)); // enable TC1 RA and RB capture interrupts
REG_TC0_IMR1 = ((1 << LDRAS) | (1 << LDRBS)); // enable TC1 capture interrupt mask
REG_TC0_IDR1 = !((1 << LDRAS) | (1 << LDRBS)); // disable all other timer interrupts except capture
NVIC_EnableIRQ(TC1_IRQn); // enable TC1 interrupts
// print the startup header
Serial.println("Timer Capture");
// use the DUE to output a PWM frequency on pin 7, pin A7 input to the timer capture, just for testing
pinMode(A7, INPUT); // TIOA1, input to TC1 for capture, A7 on DUE
// analogWrite(7,127); // start PWM signal on pin 7, 50% duty cycle
analogWrite(7,64); // start PWM signal on pin 7, 25% duty cycle
// a jumper needs to be installed between pin 7 (PWM output) and A7 (TC0,1 TIOA pin)
if (CaptureFlag) {
CaptureFlag=0;
Serial.print(CaptureCountA);
Serial.print(", ");
Serial.print(CaptureCountB);
Serial.print(", ");
Serial.println(TimerCount);
else {
Serial.println(REG_TC0_CV1);
void TC1_Handler(){
TimerCount=REG_TC0_CV1; // save the timer counter register, for testing
TC_GetStatus(TC0, 1); // get status, TC0 channel 1, allow the interrupt to fire again
if (MTIOA) {
CaptureCountA = REG_TC0_RA1; // get data from capture register A for TC0 channel 1
else {
CaptureCountB = REG_TC0_RB1; // get data from caputre register B for TC0 channel 1
CaptureFlag=1; // set flag idicating a new capture value present
