I trying to use SDA1 and SCL1 (TWI0), but i don't know how to configure the Wire.h library (or Wire.cpp).
I didn't find where Arduino configure the use of TWI1...
any suggestion?
Thanks in Advance
Tomer
any suggestion?
Thanks in Advance
Tomer
Hello fichmant,
Replace any wire.xxx function with the correspondent wire1.xxx. And don't forget to use 4.7K pull-up resistors.
You don't need to touch the Wire library (.h,.cpp) or the class(TwoWire). The pin definition for Wire1 is already defined in Wire (.h,.cpp) and variant (.h,.cpp).
Regards,
p
If I am using 2 LCD with same non configurable address can anyone post a code how can communicate with both LCD using SCL/SDA and SCL1/SCDA1 in Arduino Due?
hanks for your help
