Environment:
Ubuntu 8.10 Linux 32-bit machine
Duemilanova board; USB cable
Compiles and uploads successfully using IDE.
I want to be able to compile and upload from the command line. After slightly modifying the sample makefiles to fix PORT and paths, I am now building successfully to a hex file, but uploading fails consistently.
$ /home/peo/Desktop/arduino-0012/hardware/tools/avrdude -V -F -C /home/peo/Desktop/arduino-0012/hardware/tools/avrdude.conf -p atmega168 -P /dev/ttyUSB0 -c stk500v1 -b 19200 -U flash:w:applet/blink.hex -vvvv
avrdude: Version 5.4-arduino, compiled on Oct 22 2007 at 13:15:12
System wide configuration file is “/home/peo/Desktop/arduino-0012/hardware/tools/avrdude.conf”
User configuration file is “/home/peo/.avrduderc”
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: Send: Q [51] [20]
Any ideas? Is there any way I can get diagnostic output from the IDE (since it works perfectly from there) so that I compare with what I’m trying to do directly from the shell?
