I have successfully setup two way com using 2 Xbees as shown in the pictures here: http://www.robotshop.com/forum/showthread.php?614-Xbee-Series-2-Point-to-Point-Duplex-Configuration . Prior to installing Xbee I was able to control the motors/servos using code uploaded from the Arduino environment. The Xbee shield fitted to the Duemilanove blocks Pins 0 (RX) & 1 (TX) which I previously used to connect both controller boards. My most recent code tries to use the NewSoftSerial Library. Should this work ok?
Sample code for RobotShop Rover v1.0
www.RobotShop.com
#include <Wire.h>
#include <NewSoftSerial.h>
#define MIN_POS0 1800 // the minuimum pulse width for your servos
#define MAX_POS0 4200 // maximum pulse width for your servos
#define MIN_POS1 2700 // the minuimum pulse width for your servos
#define MAX_POS1 4000 // maximum pulse width for your servos
#define srfAddress 0x70 // Address of the SRF08
#define cmdByte 0x00 // Command byte
#define lightByte 0x01 // Byte to read light sensor
#define rangeByte 0x02 // Byte for start of ranging data
// set servo speed, goes from 1 to 127
int servoSpeed = 120; // 1 = fastest 127 = slowest
int motor_reset = 2; //digital pin 2 assigned to motor reset
int irpin = 3;
int speakerOut = 9;
NewSoftSerial mySerial = NewSoftSerial(4, 5);
int idistance = 0;
int period;
int timeUp = 680; // 1000000/(2 * frequency)
int pos0 = 3000;
int pos1 = 2500;
long loopcount = 0;
struct t_mtab { char c, pat; } ;
struct t_mtab morsetab[] = {
#define N_MORSE (sizeof(morsetab)/sizeof(morsetab[0]))
#define SPEED (10)
#define DOTLEN (1200/SPEED)
#define DASHLEN (3*(1200/SPEED))
int distance = 0; // variable for storing the distance (cm)
byte highByte = 0x00; // Stores high byte from ranging
byte lowByte = 0x00; // Stored low byte from ranging
void
dash()
void
dit()
void
send(char c)
void
sendmsg(char *str)
pinMode(motor_reset, OUTPUT);
pinMode(speakerOut, OUTPUT);
Wire.begin(); // join i2c bus (address optional for master)
mySerial.begin(9600);
delay(100);
// reset motor controller
digitalWrite(motor_reset, LOW);
delay(50);
digitalWrite(motor_reset, HIGH);
delay(50);
// set servo pin and speed
if (servoSpeed >= 1 && servoSpeed <= 127)
servoSetSpeed(0, servoSpeed);
servoSetSpeed(1, servoSpeed);
int softRev = getSoft(); // Calls function to get software revision
Serial.println(softRev);
pos0 = 2900;
if (pos0 > MAX_POS0)
pos0 = MAX_POS0;
if (pos0 < MIN_POS0)
pos0 = MIN_POS0;
servoSetPosition(0, pos0);
delay(25);
pos1 = 2700;
if (pos1 > MAX_POS1)
pos1 = MAX_POS1;
if (pos1 < MIN_POS1)
pos1 = MIN_POS1;
servoSetPosition(1, pos1);
delay(25);
loopcount++;
if (Serial.available() > 0) {
int b = Serial.read();
if (b == 's')
motorstop();
delay(100);
sonicdetection();
if (b == 'j')
motorstop(); // stop the motors
delay(100);
rotateccw(); // rotate for 1 second
delay(100);
sonicdetection();
if (b == 'k')
delay(100);
rotatecw(); // rotate for 1 second
delay(100);
sonicdetection();
if (b == 'i')
motorforward();
irdetection();
delay(100);
if (b == 'm')
Serial.println(b);
sendmsg("SOS") ;
motorreverse();
delay(5000);
motorstop();
delay(100);
Serial.flush();
if (loopcount > 50000L)
irdetection();
loopcount = 0;
void itoa(int n, int type)
int getRange(){ // This function gets a ranging from the SRF08
int getLight(){ // Function to get light reading
int getSoft(){ // Function to get software revision
void irdetection()
void sonicdetection()
//subroutine motor forward
void motorforward()
//left motor
unsigned char buff1[6];
buff1[0]=0x80; //start byte - do not change
buff1[1]=0x00; //Device type byte
buff1[2]=0x01; //Motor number and direction byte; motor one =00,01
buff1[3]=0x45; //Motor speed "0 to 128" (ex 100 is 64 in hex)
for(int i=0; i<4; i++) {mySerial.print(buff1[i], BYTE);}
//right motor
unsigned char buff2[6];
buff2[0]=0x80; //start byte - do not change
buff2[1]=0x00; //Device type byte
buff2[2]=0x03; //Motor number and direction byte; motor two=02,03
buff2[3]=0x45; //Motor speed "0 to 128" (ex 100 is 64 in hex)
for(int i=0; i<4; i++) {mySerial.print(buff2[i], BYTE);}
//subroutine reverse at half speed
void motorreverse()
//left motor
unsigned char buff3[6];
buff3[0]=0x80; //start byte - do not change
buff3[1]=0x00; //Device type byte
buff3[2]=0x00; //Motor number and direction byte; motor one =00,01
buff3[3]=0x35; //Motor speed "0 to 128" (ex 100 is 64 in hex)
for(int i=0; i<4; i++) {mySerial.print(buff3[i], BYTE);}
//right motor
unsigned char buff4[6];
buff4[0]=0x80; //start byte - do not change
buff4[1]=0x00; //Device type byte
buff4[2]=0x02; //Motor number and direction byte; motor two=02,03
buff4[3]=0x35; //Motor speed "0 to 128" (ex 100 is 64 in hex)
for(int i=0; i<4; i++) {mySerial.print(buff4[i], BYTE);}
//Motor all stop
void motorstop()
//left motor
buff3[3]=0x00; //Motor speed "0 to 128" (ex 100 is 64 in hex)
//right motor
buff4[3]=0x00; //Motor speed "0 to 128" (ex 100 is 64 in hex)
void rotatecw()
//left motor
buff1[2]=0x00; //Motor number and direction byte; motor one =00,01
buff1[3]=0x40; //Motor speed "0 to 128" (ex 100 is 64 in hex)
//right motor
buff2[3]=0x40; //Motor speed "0 to 128" (ex 100 is 64 in hex)
void rotateccw()
//left motor
//right motor
buff2[2]=0x02; //Motor number and direction byte; motor two=02,03
void servoSetPosition(int servo, int angle)
//servo is the servo number (typically 0-7)
//angle is the absolute position from 500 to 5500
unsigned char buff[6];
unsigned int temp;
unsigned char pos_hi,pos_low;
//Convert the angle data into two 7-bit bytes
temp=angle&0x1f80;
pos_hi=temp>>7;
pos_low=angle & 0x7f;
//Construct a Pololu Protocol command sentence
buff[0]=0x80; //start byte: always 0x80
buff[1]=0x01; //device id: always 0x01 for an pololu 8 servo controller
buff[2]=0x04; //command number: 0x04 to set absolute values
buff[3]=servo; //servo number: 0 to 7
buff[4]=pos_hi; //data1
buff[5]=pos_low; //data2
//Send the command to the servo controller
for(int i=0;i<6;i++){
mySerial.print(buff[i],BYTE);
void servoSetSpeed(int servo, int speed){
//speed is servo speed (1=fastest, 127=slowest)
//set speed to zero to turn off speed limiting
unsigned char buff[5];
unsigned char speedcmd;
speedcmd=speed&0x7f;//take only lower 7 bits of speed
buff[0]=0x80;//start byte
buff[1]=0x01;//device id
buff[2]=0x01;//command number
buff[3]=servo;//servo number
buff[4]=speed;//data1
for(int i=0;i<5;i++){
