Duemilanove +5V pin amperage?
What's the max amperage available from the +5V pin on the Duemilanove?
I'm hooking up 3 RGB common anode LEDs in parallel (each color is in parallel so I'd have 1 anode and 3 cathodes, 1 of each color) and was wondering if I can have the +5V pin power the anode.
LED specs: FW current: 30mA (green/blue), 50mA (red) FW supply: 3.5V typical, 4.0V max (green/blue); 2.0V typical, 2.6V max (red)
You can get about 400mA through the regulator without it getting too hot. See:- http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
Thanks again, Grumpy_Mike!!! :)
And if your using USB power then the limit is around 500ma total and is protected by a thermofuse.
Lefty
