I just got my first Arduino, a Duemilanove168.
I'm trying to get it to work with Blink,
but failing to upload the code.
I'm using Ubuntu 10.10 w/ Arduino 0018.
I trying using the software as root and encountered the same problem.
I set up Board to Duemilanove168,
and Serial Port to ttyUSB0 (which appeared only after I connected the Arduino).
Here's the output I get:
Binary sketch size: 896 bytes (of a 14336 byte maximum)
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega168 -carduino -P/dev/ttyUSB0 -b19200 -D -Uflash:w:/tmp/build8160479639104660975.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Jun 29 2010 at 03:44:14
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
