Duemilanove ATmega328 doesn't upload
Hi guys,
I am trying to upload a code to connect my Duemilanove ATmega328 with Mindwave over bluetooth using BlueSMiRF. I’ve downloaded a code from the web and solve a few problems but ! Now I am facing uploading problem.
It says
Could anyone help me with this? I would very much appreciate your help.
// Arduino BlueSMiRF initial baudrate changer
// This is example code provided by NeuroSky, Inc. and is provided
// license free.
// * Connect BlueSMiRF RX and TX to Serial on Arduino board (pins 0 & 1)
// * Connect BlueSMiRF VCC to the pin corresponding to BLUESMIRFON
/**** CleanProgramBlueSMiRF.pde ****
** Modified by Sean M Montgomery 2010/12
** Programs a BlueSMiRF module with the specified MAC address
** for use with the NeuroSky MindSet.
** Modified to do an automatic factory reset to avoid needing
** to run the program twice.
/**** SET YOUR MAC ADDRESS HERE ****/
char mac[13] = "74E543BE4210";
#define LED 13
#define BLUESMIRFON 2
#define FACTORYRESETBAUD 57600
#define DEFAULTBAUD 115200
char str[3];
char passkey[5] = "0000";
boolean success = false;
int failOuts[10] = {3,4,5,6,7,8,9,10,11,12};
  //Initialize pins
  pinMode(LED, OUTPUT);
  pinMode(BLUESMIRFON, OUTPUT);
  for (int i=0; i<10; i++) {
    pinMode(failOuts[i], OUTPUT);
  // First reset to factory defaults
  while (!success) {
    RunBlueSmirfSetup(true);
  success = false;
  // Then set up with the correct mac address
  RunBlueSmirfSetup(false);
  if(success) {
    digitalWrite(LED,LOW);
    digitalWrite(LED,HIGH);
void RunBlueSmirfSetup(boolean factoryReset) {
  //Initialize serial ports
  if (factoryReset) {
    Serial.begin(FACTORYRESETBAUD);
    Serial.begin(DEFAULTBAUD);
  digitalWrite(BLUESMIRFON, LOW);
  delay(2000);
  digitalWrite(BLUESMIRFON, HIGH);
  delay(2000);              //Wait for BlueSMIRF to turn on
  Serial.print('
);      //Send command to put BlueSMIRF into programming mode
  Serial.print(’
  Serial.print('
  delay(100);
  Serial.flush();
  //Reset the module
  if (factoryReset) {
    Serial.print(‘S’);
    Serial.print(‘F’);
    Serial.print(’,’);
    Serial.print(‘1’);
    Serial.print(’\r’);
    while(Serial.available() < 3);
    str[0] = (char)Serial.read();
    str[1] = (char)Serial.read();
    str[2] = (char)Serial.read();
    if(str[0] == ‘A’ && str[1] == ‘O’ && str[2] == ‘K’) {
      success = true;
      success = false;
      digitalWrite(failOuts[0],HIGH);
    delay(100);
    Serial.flush();
    //Set the baudrate
    Serial.print(‘S’);
    Serial.print(‘U’);
    Serial.print(’,’);
    Serial.print(‘5’);
    Serial.print(‘7’);
    Serial.print(’\r’);
      success = true;
      success = false;
      digitalWrite(failOuts[1],HIGH);
    delay(100);
    Serial.flush();
    //Set the remote MAC address
    Serial.print(‘S’);
    Serial.print(‘R’);
    Serial.print(’,’);
    for(int i = 0; i < 12; i++) {
      Serial.print(mac[i]);
    Serial.print(’\r’);
      success = true;
      success = false;
      digitalWrite(failOuts[2],HIGH);
    delay(100);
    Serial.flush();
    //Set the passkey
    Serial.print(‘S’);
    Serial.print(‘P’);
    Serial.print(’,’);
    for(int i = 0; i < 4; i++) {
      Serial.print(passkey[i]);
    Serial.print(’\r’);
      success = true;
      success = false;
      digitalWrite(failOuts[3],HIGH);
    delay(100);
    Serial.flush();
    //Set the BlueSMiRF mode
    Serial.print(‘S’);
    Serial.print(‘M’);
    Serial.print(’,’);
    Serial.print(‘3’);
    Serial.print(’\r’);
      success = true;
      success = false;
      digitalWrite(failOuts[4],HIGH);
    delay(100);
    Serial.flush();
    delay(100);
    //Exit command mode
  Serial.print(’-’);
  Serial.print(’-’);
  Serial.print(’-’);
  Serial.print(’\r’);
//delay(100);
  //Serial.flush();
  //delay(100);
  //Serial.end();
  //digitalWrite(BLUESMIRFON, LOW);
//CleanProgramBlueSMiRF CleanProgramBlueSMiRF
Do you have something connected to pins 0 and 1?
Yes. Do I have to burn the boot loader?
egbalove: Yes.
Pins 0 and 1 are connected to the hardware Serial UART which is used to talk to the PC and needed when you upload a sketch.
You need to either disconnect your circuit from pins 0 and 1 while you're uploading, or change your sketch to use SoftwareSerial on two different pins and then connect the bluetooth device to those pins instead.
