Duemilanove Power Question
What happens when you give the duemilanove power from both the Usb port and the 2.1mm jack?
Which one does it use?
It uses the external power if it's at around 7.5vdc or higher. If lower or removed then the power is sourced from the USB connector. If both are presenet then the external is selected.
Lefty
