Duemilanove Upload Error
I just received an Arduino Starter kit containing a Arduino Duemilanove. As soon as I received the kit I plugged it into my computer (iMac G5 1.8 GHZ processor, 256 MB RAM, 80 GB hard drive, Mac OS X 10.4.11, Arduino software version 012) using the included USB cable. Once it was connected I attempted to upload the Blink sample sketch. When I pressed the upload to I/O board button after 5-10 seconds I received an error stating the following:
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
After I saw the error I proceeded to try multiple things in an attempt to fix it. I checked everything on the Arduino troubleshooting page, restarting the program, restarting my computer, and pressing the reset button in various increments before upload to the board. I would really appreciate if anyone knew how to fix this or even had a guess. Thanks in advance!
Hey, I had the same error. I realized that I had set it on the wrong serial port. You should see the TX and RX leds flash when your successfully uploading.
Thank you so much! That fixed my problem completely. Now sketches are uploading perfectly. Thanks again! :smiley:
