My data loggers create new files at midnight, using the date as the file name e.g. 20141213.csv.
I want to be able to download the contents of selected files via serial.
I am using some old zoomkat stuff which uses readString. This enables me to enter six digits - 141213. I can combine this with fixed items to get a String - 20141313.csv.
It looks like what I want, but it appears to need to be a char. How can I sensibly convert it?
// zoomkat 8-6-10 serial I/O string test
#include <SD.h>
const int chipSelect = 4;
String readString;
String stringFive, stringSix, stringSeven;
char dumpName[] = "00000000.CSV";
File dumpFile;
stringFive = String("20");
stringSix = String(".csv");
pinMode(53, OUTPUT); //Mega
while (Serial.available())
delay(3);
char c = Serial.read();
readString += c;
}// end while
if (readString.length() >0) {
Serial.print("readString= ");
Serial.println(readString);
stringSeven = stringFive + readString + stringSix;
Serial.print("stringSeven ");
Serial.println(stringSeven);
// Do something here!
getDump();
// reset string
readString="";
} // end if
}// end loop
void getDump() {
File dumpFile = SD.open(dumpName);
Serial.print("dumpName = ");
Serial.println(dumpName);
// if the file is available, write to it:
if (dumpFile) {
while (dumpFile.available()) {
Serial.write(dumpFile.read());
dumpFile.close();
// if the file isn't open, pop up an error:
else {
Serial.println("error opening file");
#include <SD.h>
String readString;
File dumpFile;
char charBuf [13];
Serial.begin(9600); // this is not likely to be fast enough
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect))
Serial.println("Card failed");
// don't do anything more:
return;
Serial.println("CARD OK");
delay(3);
readString += c;
}// end while
stringSeven.toCharArray(charBuf, 13);
getDump();
// reset string
readString="";
} // end if
}// end loop
void getDump() {
File dumpFile = SD.open(charBuf);
if (dumpFile) {
dumpFile.close();
else {
This silly mess REALLY needs a comment to not be considered a silly mess. There is NO reason to create an instance of the String class, invoke the copy operator and destroy that instance of the String class just to assign the value "20" to stringFive.
stringFive = "20";
works perfectly well and pisses away far fewer resources.
