well, a productive weekend it has been. I have gotten most of my code together, and need some pointers on it.
engine rpm is provided by this: http://www.sportdevices.com/rpm_readings/SP1%20ignition%20sense.gif
rear wheel speed is provided by a magnet on the brake rotor and a magnetic reed switch
looking at providing battery voltage on the screen to help with performance, it is a homemade 4s 12.8V LiFE battery. suggestions on this are appreciated.
Inside the SDWrite function, it says that += is not valid, operand types are 'string [1]' and 'string'
yes, i know that i dont have everything correct yet
/*Baja Dash display
* Coded by: *************
* Rev 1 created 9/7/15
// ----------LIBRARIES--------------
#include <LiquidCrystal.h>
#include <SPI.h>
#include <SD.h>
#include <String.h>
// --------CONSTANTS (won't change)---------------
//pin inputs
//Engine RPM = 2;
//Rear wheel RPM = 3;
//SD uses 11, 12, 13, a5
//lcd uses 4-10
//batery voltage a1?
const int buttonPin = A0;
//speed factors
const int tireDiameter = 24;
const int MPHCoef = 178500;
//data file header
char header[] = "Engine_rpm, Wheel_speed, time";
//------------ VARIABLES (will change)---------------------
//screen stuffs
int screen = 0;
int Update = 1000;
unsigned long lastMillis = 0;
unsigned long currMillis = 0;
int z;
//stopwatch variables
boolean timer = false;
unsigned long start, finished, elapsed;
long lastSSTime = 0; // the last time the timer was triggered
float h, m, s, ms;
unsigned long over;
int x, y;
//RPM variables
int E_count = 0;
int E_rpm = 0;
int RW_count = 0;
int RW_rpm = 0;
int RW_mph = 0;
//sd card variables
char filename[] = "LOGGER00.CSV";
String line[] = "";
int w;
boolean record = false;
boolean recording = false;
long lastRecTime = 0; // the last time the recorder was triggered
//extras
long debounceDelay = 50; // the debounce time for lcd buttons; keep this as low as possible
//------------ SD CARD ---------------------
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = A5;
File logFile;
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
Serial.begin(9600); // Open serial communications and wait for port to open
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(8,1);
lcd.print("00:00:00");
AttachInterrupts();
CheckStartStop();
CheckResetTimer();
//CheckScreenSwitch();
CheckStartStopLogger();
currMillis = millis();
if(currMillis - lastMillis >= Update){
DetachInterrupts(); //allows calculations to be carried out without interuption
CalcRPMs();
if(screen == 0){
DisplayTimerResult();
DisplayRPM();
if(screen == 1){ //UNRELIABLE and untested
lcd.setCursor(0,0);
lcd.print("test");
if(recording == true){
SDWrite();
lastMillis = millis();
AttachInterrupts();
void CheckStartStop(){
x = analogRead (0); // assign 'x' to the Arduino's AnalogueInputs (Shield's buttons)
if (x < 800 && x > 600 ){ // if the button is SELECT
if ((millis() - lastSSTime) > debounceDelay){
if (timer == false){
start = millis(); // saves start time to calculate the elapsed time
timer = !timer;
lastSSTime = millis();
void DisplayTimerResult(){
if (timer == true){
finished = millis(); // saves stop time to calculate the elapsed time
//calculating the timer
elapsed = finished - start;
h = int(elapsed / 3600000);
over = elapsed % 3600000;
m = int(over / 60000);
over = over % 60000;
s = int(over / 1000);
ms = over % 1000;
// display the results
lcd.setCursor(8, 1); // Move the cursor to column four, lower row
if (h<10){ // Add a zero, if necessary, as above
lcd.print(0);
lcd.print(h, 0); // Display the current hour
lcd.setCursor(10, 1); // Move to the next column
lcd.print(":"); // And print the colon
if (m<10){ // Add a zero, if necessary, as above
lcd.print(0);
lcd.print(m, 0); // Display the current minute
lcd.setCursor(13, 1); // Move to the next column
if (s<10){ // Add a zero, if necessary, as above
lcd.print(0);
lcd.print(s, 0); // Display the current second
void CheckResetTimer(){
y = analogRead (0); // assign 'z' to the Arduino's AnalogueInputs (Shield's buttons)
if (y < 420 && y > 350){ // if the button is LEFT
if(timer==false){
lcd.setCursor(8,1);
void CheckScreenSwitch(){
z = analogRead (0); // assign 'z' to the Arduino's AnalogueInputs (Shield's buttons)
if (z < 20 ){ // if the button is RIGHT
if(screen == 0){
lcd.clear();
screen = 1;
if(screen == 1){
lcd.clear();
screen = 0;
void AttachInterrupts(){
E_rpm = 0;
RW_rpm = 0;
attachInterrupt(0, e_rpm, RISING);
attachInterrupt(1, rw_rpm, RISING);
void e_rpm(){
E_count++;
void rw_rpm(){
RW_count++;
void DetachInterrupts(){
detachInterrupt(0);
detachInterrupt(1);
void CalcRPMs(){
//engine rpm
E_rpm = E_count * (currMillis-lastMillis);
//rear wheel rpm
RW_rpm = RW_count * (currMillis-lastMillis);
RW_mph = (RW_rpm * tireDiameter * 3.14 * 60)/63360;
void DisplayRPM(){
// wheel speed
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0, 0);
if(RW_mph <= 2){
lcd.print("000");
else{
lcd.print(RW_mph, 1);
lcd.print("MPH");
lcd.setCursor(7, 0);
lcd.print(" ");
lcd.print(E_rpm, 0);
lcd.print("RPM");
void CheckStartStopLogger(){
w = analogRead (0); // assign 'w' to the Arduino's AnalogueInputs (Shield's buttons)
if (w < 110 && w > 80 ){ // if button is UP
if ((millis() - lastRecTime) > debounceDelay){
if (record == false){
recording = true;
CreateFile();
if(record == true){
recording = false;
logFile.close(); //saves and closes the file
record = !record;
lastRecTime = millis();
void CreateFile(){
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logFile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
lcd.setCursor(16,0);
if(! logFile) {
lcd.print("E");
recording = false;
record = false;
else{
lcd.print("R");
void SDWrite(){//Engine_rpm, Wheel_speed, time";
line += String(E_rpm);
line += ",";
line += String(RW_mph);
line += ",";
line += String(millis());
logFile.println(line);
line = "";
