Hey good people, my code controls relays and fans in a box. The code works great but it locks up after only a few hours. Ive taken out everything I can to make it less work, but it still manages to lock up after a few hours.
I ended up making it reset itself after 4 hours in an effort to beat this but it only runs a few days then stops.
I have a few things to add to the system, like a data logger. Was thinking I might have to go to a Arduino Mega to have enough pins, would that make any differnece?
#include <Wire.h>
#include <DHT.h>
#define DHTPIN 11 // what pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Initialize DHT sensor for normal 16mhz Arduino
DHT dht(DHTPIN, DHTTYPE);
//DHT dht(DHTPIN, DHTTYPE, 30);
int humidfan = 2; // Intake fan for Humid box
int humidv = 3; // Valve for humud intake
int freshfan = 4; // fresh fan
int freshv = 5; // fresh valve, air from outside
int exfan = 6; // exhaust fan
int exv = 7; // exhaust valve
int dryfan = 8; // intake fan for dry box
int dryv = 9; // dry box valve
const int resetPin = 10; // button to reset cycle
// DHT pin 11
int DHTpower = 13; // constant 5v to DHT11
int fridge = 12; // relay to fridge 240v
int buttonState = 0; // variable for reading the pushbutton
void(* resetFunc) (void) = 0;
const int TEMP_LOWER = 19; // low
const int TEMP_UPPER = 21; //
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 14400000; //the value is a number of milliseconds - 4 hours 14400000
float temperature;
LiquidCrystal_I2C lcd(0x27, 20, 4); // Set the LCD address to 0x27 for a 20x4 display
pinMode(humidfan, OUTPUT);
pinMode(dryfan, OUTPUT);
pinMode(fridge, OUTPUT);
pinMode(humidv, OUTPUT);
pinMode(dryv, OUTPUT);
pinMode(exfan, OUTPUT);
pinMode(exv, OUTPUT);
pinMode(freshfan, OUTPUT);
pinMode(freshv, OUTPUT);
pinMode(DHTpower, OUTPUT);
pinMode(resetPin, OUTPUT);
digitalWrite(resetPin, HIGH);
digitalWrite(humidfan, LOW);
digitalWrite(dryfan, LOW);
digitalWrite(humidv, LOW);
digitalWrite(dryv, LOW);
digitalWrite(exfan, LOW);
digitalWrite(exv, LOW);
digitalWrite(freshfan, LOW);
digitalWrite(freshv, LOW);
digitalWrite(DHTpower, HIGH);
digitalWrite(fridge, LOW);
lcd.init(); // Initialize the LCD
lcd.backlight(); // Turn on the backlight
lcd.clear(); // Clear the LCD screen
lcd.setCursor(5, 1);
lcd.print("The Green");
lcd.setCursor(6, 2);
lcd.print("Ninja");
delay(2200); // Display the startup message for 2 seconds
lcd.clear();
dht.begin();
float h = dht.readHumidity();
// Read temperature as Celsius
float t = dht.readTemperature();
// Read temperature as Fahrenheit
float f = dht.readTemperature(true);
// float currentDew = dewPoint(t, h); // Dew Point for setting pins high
temperature = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Failed to read");
lcd.setCursor(0, 1);
lcd.print("from DHT sensor");
return;
if (temperature < TEMP_LOWER) {
digitalWrite(fridge, LOW); // turn on
lcd.setCursor(0, 2);
lcd.print("Cooling Off ");
if (temperature > TEMP_UPPER) {
digitalWrite(fridge, HIGH); // turn on
lcd.print("Cooling On ");
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
resetCycle(h);
if ((h > 58 && (h < 65))) {
humPointOk(h);
if (h > 65.5) { // High dew point, send to dry box
humPointHigh(h);
if (h < 57.5) { // Dew point low, send to humid box
humPointLow(h);
void resetCycle(float h) {
lcd.clear();
lcd.print("Exhaust fan on");
lcd.print("Fresh air in");
lcd.print("Cooling on ");
digitalWrite(exv, HIGH);
digitalWrite(freshv, HIGH);
delay(4000);
digitalWrite(freshfan, HIGH);
digitalWrite(exfan, HIGH);
delay(150000);
resetFunc();
void humPointOk(float h) {
//lcd.clear();
lcd.print("Humidity");
lcd.setCursor(14, 0);
lcd.print(dht.readHumidity());
lcd.setCursor(19, 0);
lcd.print("%");
lcd.print("Temp");
lcd.setCursor(14, 1);
lcd.print(dht.readTemperature());
lcd.setCursor(19, 1);
lcd.print("c");
lcd.setCursor(0, 3);
lcd.print("Valves Closed");
delay(4000);
void humPointHigh(float h) {
digitalWrite(dryv, HIGH);
//lcd.clear();
lcd.print("%");
lcd.print("Temp");
lcd.print("c");
lcd.print("Dry Box On ");
delay(4000);
digitalWrite(dryfan, HIGH);
void humPointLow(float h) { // humid box on
digitalWrite(humidv, HIGH);
//lcd.clear();
lcd.print("%");
lcd.print("Temp");
lcd.print("c");
lcd.print("Humid Box On");
delay(4000);
digitalWrite(humidfan, HIGH);
