Duplicate rows on 32 x 64 LED Matrix (Arduino Mega)
I'm trying to make a countdown timer using a 32 x 64 LED Matrix and an Arduino Mega. I'm not sure why every time I send a string to the display, it duplicates it on the next row. I'd appreciate some help.
I followed this wiring diagram.
https://www.instructables.com/64x32-RGB-LED-Matrix-With-Arduino-Mega/
Arduino Issue
Here is my code
// testshapes demo for RGBmatrixPanel library.
// Demonstrates the drawing abilities of the RGBmatrixPanel library.
// For 32x64 RGB LED matrix.
// https://www.instructables.com/64x32-RGB-LED-Matrix-With-Arduino-Mega/
// https://learn.adafruit.com/32x16-32x32-rgb-led-matrix/library
// https://tutorial45.com/building-an-arduino-countdown-timer/
// WILL NOT FIT on ARDUINO UNO -- requires a Mega, M0 or M4 board
#include <RGBmatrixPanel.h>
// Most of the signal pins are configurable, but the CLK pin has some
// special constraints.  On 8-bit AVR boards it must be on PORTB...
// Pin 11 works on the Arduino Mega.  On 32-bit SAMD boards it must be
// on the same PORT as the RGB data pins (D2-D7)...
// Pin 8 works on the Adafruit Metro M0 or Arduino Zero,
// Pin A4 works on the Adafruit Metro M4 (if using the Adafruit RGB
// Matrix Shield, cut trace between CLK pads and run a wire to A4).
//#define CLK  8   // USE THIS ON ADAFRUIT METRO M0, etc.
//#define CLK A4 // USE THIS ON METRO M4 (not M0)
#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE   9
#define LAT 10
#define A   A0
#define B   A1
#define C   A2
#define D   A3
int S = 59; // count seconds
int M = 59; // count minutes
int H = 47; // count hours
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false,64); //add D after C,....and 64 after false,
  matrix.begin(); //this line is needed for anything to show up\
  matrix.setCursor(9,0);
  matrix.setTextColor(matrix.Color333(7,7,0));
  matrix.print("GO");
  matrix.setTextColor(matrix.Color333(7,7,7));
  matrix.print("CREATE");
  //------------------------------CHANGE TIME---------------------------------
    S--;
    matrix.fillScreen(0); //to refresh
    matrix.setTextColor(matrix.Color333(0,0,0));
    //DISPLAY MAKE 48 LOGO
    matrix.setCursor(11,0);
    matrix.setTextColor(matrix.Color333(4,7,0));
    matrix.print("MAKE");
    matrix.setTextColor(matrix.Color333(7,4,0));
    matrix.print(" 48");
    if (S<0) //if seconds are up,
      M--; // reduce minute by one
      S=59; // reset second section to 59
    if (M<0) //if minutes are up,
      H--; //reduce hour by one
      M=59; //reset minute to 59
    if (H<0){ //if hours are up, reset everything
      H=23;
      M=59;
      S=59;
    //----------------------------DISPLAY TIME-----------------------------
    matrix.setCursor(8,16);
    if (H>=32){ // Set color for time
    } else if (H <32 && H>=16){
    } else{
       matrix.setTextColor(matrix.Color333(7,0,0));
    if (H < 10){
      matrix.print(" "); //Extra space is to ensure colons are in the same spot when theres only 1 digit
      matrix.print(H);
      matrix.print(H);
    matrix.print(":");
    if (M < 10){
      matrix.print(M);
      matrix.print(M);
    matrix.print(":");
    if (S < 10){
      matrix.print(S);
      matrix.print(S);
Why did you start a new topic? Duplicate rows on 32 x 64 LED Matrix display has a few replies.
