Durchschnittsberechnung average
Hallo ich hab diesen Programmteil rauskopiert.
Ich finde eine Durchschnittsberechnung interessant. Kann jemand diesen code erläutern?
Speziell diese zwei Zeilen:
val = constrain(val, 1, senseLimit);  // turn any reading higher than the senseLimit value into the senseLimit value
val = map(val, 1, senseLimit, 1, 1023);  // remap the constrained value within a 1 to 1023 range
Der ganze sketch:
#define NUMREADINGS 15 // raise this number to increase data smoothing
int senseLimit = 15; // raise this number to decrease sensitivity (up to 1023 max)
int probePin = 5; // analog 5
int val = 0; // reading from probePin
// variables for smoothing
int readings[NUMREADINGS];                // the readings from the analog input
int index = 0;                            // the index of the current reading
int total = 0;                            // the running total
int average = 0;                          // final average of the probe reading
//CHANGE THIS TO affect the speed of the updates for numbers. Lower the number the faster it updates.
int updateTime = 40;
 Serial.begin(9600);  // initiate serial connection for debugging/etc
 for (int i = 0; i < NUMREADINGS; i++)
   readings[i] = 0;                      // initialize all the readings to 0
 val = analogRead(probePin);  // take a reading from the probe
 if(val >= 1){                // if the reading isn't zero, proceed
   total -= readings[index];               // subtract the last reading
   readings[index] = val; // read from the sensor
   total += readings[index];               // add the reading to the total
   index = (index + 1);                    // advance to the next index
   if (index >= NUMREADINGS)               // if we're at the end of the array...
     index = 0;                            // ...wrap around to the beginning
   average = total / NUMREADINGS;          // calculate the average
   if (average > 50){                // if the average is over 50 ...
     showLED0();   // Show a 0
   Serial.println(average); // use output to aid in calibrating
   delay(updateTime);
Guckst du die Arduino Referenz (im Teil Math) zu map und constrain an.
Hi
Hmm - wenn man Englisch kann, ergibt Das direkt einen Sinn (constrain <-> beschränken).
Hätte bei dem Problem wohl mit min und max um mich geworfen ... wieder was gelerntQ!
MfG
funktioniert dieser sketch? warum dieses remap?
mein ziel war es etwas entfernt vom durchschnitt zu aktivieren.
die updatetime=40;?
40 sekunden?
andi_86x:
die updatetime=40;?
40 sekunden?
remap k.A.
40 ms
