Hello dears.
I am working on a prototype to measure the density of dust with a TTGO LoRa32 V2.1_1.6 and with a Sharp GP2Y1010AU0F sensor. The code compiles me and is loaded to the Lora32 without problems but when reading the data on the screen or on the serial monitor it marks zero in all the results "Voltage, density of dust" we think that we could be connecting the sensor wrong to the board "int ledPower = 12; // Digital pin for the IRED - int measurePin = 36; // Analog pin for the Vo pin of the GP2Y10 sensor" Please if you could help me to correctly define the pins that I should connect to the Lora32 .
Sorry if I write something wrong, I'm not that good with the English language.
Thanks for your help.
//TTGO ESP32 LoRa Sensor Node Code
//Libraries for LoRa
#include <U8g2lib.h>
#include <SPI.h>
#include <LoRa.h>
#include <GP2YDustSensor.h>
//Declaracion de variables//
int ledPower = 12; // Pin digital para el IRED
int measurePin = 36; // Pin analógico para el pin Vo del sensor GP2Y10
GP2YDustSensor dustSensor(GP2YDustSensorType::GP2Y1010AU0F, ledPower, measurePin);
//Definir los pines utilizados por el módulo transceptor LoRa
#define SCLK 5
#define MISO 19
#define MOSI 27
#define CS 18
#define RST 23
#define DIO 26
//Definicion frecuencia
#define BAND 915E6 //433E6 for Asia, 866E6 for Europe, 915E6 for North America
//Packet counter
int readingID = 0;
int counter = 0;
String LoRaMessage = "";
int samplingTime = 280;
int deltaTime = 40;
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
float pm05 = 0;
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
//Initialize LoRa module
void startLoRA()
LoRa.setPins(CS, RST, DIO); //Setup LoRa transceiver module
while (!LoRa.begin(BAND) && counter < 10) {
Serial.print(".");
counter++;
if (counter == 30)
//Increment readingID on every new reading
readingID++;
Serial.println("Starting LoRa failed!");
Serial.println("LoRa Initialization OK!");
delay(2000);
void startGP2YDustSensor(){
digitalWrite(ledPower,LOW);
delayMicroseconds(samplingTime); //Retardo de 0,28ms
voMeasured = analogRead(measurePin); //Se muestra el valor de voMeasured a través del pin analógico 36
delayMicroseconds(deltaTime); // Retardo de 0,04ms
digitalWrite(ledPower,HIGH); // LED desactivado
delayMicroseconds(sleepTime); // Retardo de 9,68ms
void getReadings(){
//Calcular Voltaje
// 0-5 V asignado a 0-1023 valores enteros
calcVoltage = voMeasured * (5.0 / 1024.0);
// Calcular Densidad de particulas de polvo
/*dustDensity = 0.17 * calcVoltage - 0.1; // Utilizar esta escuación para unidad mg/m3*/
dustDensity = (0.17 * calcVoltage - 0.1) * 1000; // Utilizar esta escuación para unidad ug/m3
/* Calcular material particulado (PM)
pm05 = (calcVoltage - 0.0356) * 120000; // PM 0.5(particulas/0.01 pie3)*/
// Imprimir en monitor serial
Serial.print(F("Voltaje: "));
Serial.print(calcVoltage);
Serial.print(F("% Densidad de Polvo: "));
Serial.print(dustDensity);
Serial.println(F("ug/m3"));
void sendReadings() {
LoRaMessage = String(readingID) + "/" + String(calcVoltage) + "&" + String(dustDensity) ;
//Enviar paquete LoRa al receptor
LoRa.beginPacket();
LoRa.println(LoRaMessage);
LoRa.endPacket();
Serial.print("Sending packet: ");
Serial.println(readingID);
readingID++;
Serial.println(LoRaMessage);
//initialize Serial Monitor
startGP2YDustSensor();
startLoRA();
u8g2.begin();
u8g2.clearBuffer(); //Limpiar la memoria interna
u8g2.setFont(u8g2_font_logisoso24_tr); //Elija una fuente adecuada en https://github.com/olikraus/u8g2/wiki/fntlistall
u8g2.drawStr(8,29,"Welcome"); //Escribe algo en la memoria interna
u8g2.sendBuffer(); //Transferir la memoria interna a la pantalla
//Se debe aprender a calibrar la pantalla
getReadings();
sendReadings();
u8g2.setFont(u8g2_font_pxplusibmvga9_tr); //Elija una fuente adecuada en https://github.com/olikraus/u8g2/wiki/fntlistall
u8g2.drawStr(0,15,"Dust Density "); //Escribe algo en la memoria interna
u8g2.setCursor(0, 31);
u8g2.print(dustDensity);
u8g2.drawStr(0,15,"Voltaje "); //Escribe algo en la memoria interna
u8g2.print(calcVoltage);
You may get a better response if the title is in English.
Thanks for your comment, friend
