Dust sensor and TTGO ESP32 LoRa V2 1.6
Good evening dear. I am new to the Arduino world, I am trying to create a system in which measurements can be made with the GP2Y1010AU0F dust sensor connected to a TTGO ESP32 LoRa V2 1.6 to be able to send the data to another ESP32 LoRa; But in the code I have an error ('pm' was not declared in this scope). Please if you help me correct my code or give me advice.
Beforehand thank you very much.
Best regards.
  1. #include <SPI.h>
  2. #include <LoRa.h>
  3. /* Connect to SHARP PM2.5 Sensor*/
  4. #include <PMsensor.h>
  5. PMsensor PM;
  6. #define LEDPOWER 12 //pin where the SHARP is connected
  7. #define MEASUREPIN 36 //pin where the SHARP is connected
  8. //define the pins used by the LoRa transceiver module
  9. #define SCLK 5
  10. #define MISO 19
  11. #define MOSI 27
  12. #define CS 18
  13. #define RST 23
  14. #define DIO 26
  15. #define BAND 915E6 //433E6 for Asia, 866E6 for Europe, 915E6 for North America
  16. //packet counter
  17. int readingID = 0;
  18. int counter = 0;
  19. String LoRaMessage = "";
  20. //Initialize LoRa module
  21. void startLoRA()
  22. {
  23. LoRa.setPins(CS, RST, DIO); //setup LoRa transceiver module
  24. while (!LoRa.begin(BAND) && counter < 10) {
  25. Serial.print(".");
  26. counter++;
  27. delay(500);
  28. }
  29. if (counter == 10)
  30. {
  31. // Increment readingID on every new reading
  32. readingID++;
  33. Serial.println("Starting LoRa failed!");
  34. }
  35. Serial.println("LoRa Initialization OK!");
  36. delay(2000);
  37. }
  38. void startPMsensor()
  39. {
  40. if (isnan(pm))
  41. {
  42. Serial.println("Failed to read from SHARP sensor!");
  43. return;
  44. }
  45. }
//EN ESTA PARTE ES QUE ME SALE EL ERROR.//
  1. void getReadings() {
  2.  float pm = 0;
  3.  int err = pmsensorErrSuccess;
  4.  if ((err = pm.read(&pm, true, 0.1)) != pmsensorErrSuccess) {
  5.  Serial.print("data Error = ");
  6.  Serial.println(err);
  7.  return;
  8. }
  9. Serial.print("PM2.5: ");
  10. Serial.print(pm);
  11. Serial.println(" ppm");
  12. }
  13. void sendReadings() {
  14. LoRaMessage = String(readingID) + "/" + String(pm) ;
  15. //Send LoRa packet to receiver
  16. LoRa.beginPacket();
  17. LoRa.print(LoRaMessage);
  18. LoRa.endPacket();
  19. Serial.print("Sending packet: ");
  20. Serial.println(readingID);
  21. readingID++;
  22. Serial.println(LoRaMessage);
  23. }
  24. void setup() {
  25. //initialize Serial Monitor
  26. Serial.begin(115200);
  27. PMsensor.begin();
  28. startPMsensor();
  29. startLoRA();
  30. }
  31. void loop() {
  32. getReadings();
  33. sendReadings();
  34. delay(500);
  35. }
PM is not the same thing as pm.
C++ is case-sensitive.
Please remember to use code tags when posting code AND all of your error messages.
float pm = 0;
 if ((err = pm.read(
Here, the compiler will probably mention something about "read" not being defined for objects of type float.
Thanks for your comments, indeed I have an error, request for member 'read' in 'pm', which is of non-class type 'float'
 float pm = 0;
  int err = PMsensorErrSuccess;
  if ((err = pm.read(&pm, true, 0.1)) != PMsensorErrSuccess) {
    return;
 if ((err = PM.read(&pm,
etc?
