Hello, I am currently working on a project in which I plan to use the "Dust Sensor SDS011" to read the fine dust value pm 2.5 and pm 10 and then store it on the "Data Logger Shield V 1.0". Both are connected to an "Arduino UNO".
At the beginning, I tested the storage on the SD card using the sample code "Datalogger", with which everything worked.
SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library.
The circuit:
analog sensors on analog ins 0, 1, and 2
SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
created 24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
I then tested the operation of the sensor using the sample code "quickstart" and this also worked fine.
#include "SdsDustSensor.h"
int rxPin = 0;
int txPin = 1;
SdsDustSensor sds(rxPin, txPin);
sds.begin();
Serial.println(sds.queryFirmwareVersion().toString()); // prints firmware version
Serial.println(sds.setActiveReportingMode().toString()); // ensures sensor is in 'active' reporting mode
Serial.println(sds.setContinuousWorkingPeriod().toString()); // ensures sensor has continuous working period - default but not recommended
PmResult pm = sds.readPm();
if (pm.isOk()) {
Serial.print("PM2.5 = ");
Serial.print(pm.pm25);
Serial.print(", PM10 = ");
Serial.println(pm.pm10);
// if you want to just print the measured values, you can use toString() method as well
Serial.println(pm.toString());
// notice that loop delay is set to 0.5s and some reads are not available
Serial.print("Could not read values from sensor, reason: ");
Serial.println(pm.statusToString());
I also made sure in both tests that I had chosen the correct USB port, downloaded the libraries and selected the correct pins. Nevertheless, the code I combined did not work at all. Already, after inserting the "SdsDustSensor.h" library from the second example program into the first one, the serial monitor gave only strange characters. I tested if this problem would improve after the complete combination, but now I only get mirrored question marks on the serial monitor. I also set the 9600 baud rate I implemented in the serial monitor. Below, you can see my current code and a photo of the circuit:
#include <SPI.h>
#include <SD.h>
#include <SdsDustSensor.h>
int rxPin = 6;
int txPin = 7;
while (!Serial) {
while (1);
sds.begin();
if (pm.isOk()) {
dataString += "PM2.5 = ";
dataString += pm.pm25;
dataString += ", PM10 = ";
dataString += pm.pm10;
else {
if (dataFile) {
dataFile.close();
else {
I hope you can help me find and solve the problem, thanks!
