Duty Cycles
Does anyone here have a brilliant idea how to measure this:
t2 = |<---->|
t1 = |<--------------->|
I need to measure both t1 and t2, is millis() the way to go?
This is what I try to communicate with: http://www.elfa.se/pdf/73/730/07308869.pdf
Did you check the pulseIn() command ?
http://www.arduino.cc/en/Reference/PulseIn
This is an interesting little temp sensor - I like the TO-220 case, mean you can bolt it to something - you could probably connect it directly to a analogue voltmeter and it would display something related to temperature.
If you don't need the accuracy, you could put it through a RC filter and read the temperature using an analogue in pin.
Mike
Greetings,
unsigned long t1, t2;
  pinMode(7, INPUT);
  t1 = pulseIn(7, LOW);
  t2 = pulseIn(7, HIGH);
  t1 = t1 + t2; // if needed.
Regards,
David
