Olá pessoal , sou novato com arduino tenho um problema que não conseguir achar a solução no google.
Estava analisando o código blink e tentei alterar o delay por o delayMicroseconds para ver o funcionamento , só que não funcionou !!?? Por que será? Converti 1 segundo para 1000000 microsegundos.
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model, check
the documentation at http://arduino.cc
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delayMicroseconds(1000000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
