//The default digital driver pins for the GSM and GPS mode
//If you want to change the digital driver pins
//or you have a conflict with D3~D5 on Arduino board,
//you can remove the J10~J12 jumpers to reconnect other driver pins for the module!
byte gsmDriverPin[3] = {3,4,5};
void setup(){
InitGpsMode();
void InitGpsMode(){
//Init the driver pins for GSM function
for(int i = 0 ; i < 3; i++){
pinMode(gsmDriverPin*,OUTPUT);*
- digitalWrite(3,HIGH);//Disable the GSM mode*
- digitalWrite(4,LOW);//Enable the GPS mode*
void loop(){
como o programa a cima mostra os dados a baixo na porta serial? Qual linha do programa faz esta mostra?
$GPRMC,221621.803,V,,,,,,,030812,,,N*4A
$GPVTG,,T,,M,,N,,K,N*2C
$GPGGA,221622.803,,,,,0,00,,,M,0.0,M,,0000*5A
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,221622.803,V,,,,,,,030812,,,N*49
$GPGGA,221623.803,,,,,0,00,,,M,0.0,M,,0000*5B
$GPRMC,221623.803,V,,,,,,,030812,,,N*48
$GPGGA,221624.803,,,,,0,00,,,M,0.0,M,,0000*5C
$GPRMC,221624.803,V,,,,,,,030812,,,N*4F
$GPGGA,221625.803,,,,,0,00,,,M,0.0,M,,0000*5D
$GPRMC,221625.803,V,,,,,,,030812,,,N*4E
$GPGGA,221626.803,,,,,0,00,,,M,0.0,M,,0000*5E
$GPGSV,3,1,12,10,60,263,,13,52,115,,07,51,171,25,08,51,242,*73
$GPGSV,3,2,12,28,32,338,,23,28,078,,05,16,222,,19,11,091,*7C
$GPGSV,3,3,12,04,09,307,,03,08,122,,20,08,022,,02,05,271,*70
$GPRMC,221626.803,V,,,,,,,030812,,,N*4D
$GPGGA,221627.803,,,,,0,00,,,M,0.0,M,,0000*5F
$GPRMC,221627.803,V,,,,,,,030812,,,N*4C
$GPGGA,221628.803,,,,,0,00,,,M,0.0,M,,0000*50
