//ultrasonic display data on DWIN display
//https://youtu.be/SdKTSLY3sW8
//www.alselectro.in
#include <SoftwareSerial.h>
const byte rxPin = 7;
const byte txPin = 8;
// Set up a new SoftwareSerial object
SoftwareSerial dwinSerial (rxPin, txPin);
SoftwareSerial mod(4,5); // RX, TX
/* Data frame for sensor */
unsigned char nitrogen[8]={0x5A, 0xA5, 0x05, 0x82, 0x51, 0x00, 0x00, 0x00};
unsigned char phosphorus[8]={0x5A, 0xA5, 0x05, 0x82, 0x52, 0x00, 0x00, 0x00};
unsigned char potassium[8]={0x5A, 0xA5, 0x05, 0x82, 0x53, 0x00, 0x00, 0x00};
unsigned char phlevel[8]={0x5A, 0xA5, 0x05, 0x82, 0x54, 0x00, 0x00, 0x00};
unsigned char electrical[8]={0x5A, 0xA5, 0x05, 0x82, 0x55, 0x00, 0x00, 0x00};
unsigned char moisture[8]={0x5A, 0xA5, 0x05, 0x82, 0x56, 0x00, 0x00, 0x00};
float moist, ec, pH, nitroValue, phosValue, potas;
String season,texture,variety;
dwinSerial.begin(115200);
mod.begin(4800);
byte queryData[] = {0x01, 0x03, 0x00, 0x00, 0x00, 0x07, 0x04, 0x08};
byte receivedData[19];
mod.write(queryData, sizeof(queryData)); // Send the query data to the NPK sensor
delay(1000); // Wait for 1 second
if (mod.available() >= sizeof(receivedData)) { // Check if there are enough bytes available to read
mod.readBytes(receivedData, sizeof(receivedData)); // Read the received data into the receivedData array
// Parse and print the received data in decimal format
unsigned int soilHumidity = (receivedData[3] << 8) | receivedData[4];
unsigned int soilTemperature = (receivedData[5] << 8) | receivedData[6];
unsigned int soilConductivity = (receivedData[7] << 8) | receivedData[8];
unsigned int soilPH = (receivedData[9] << 8) | receivedData[10];
unsigned int nitrogen = (receivedData[11] << 8) | receivedData[12];
unsigned int phosphorus = (receivedData[13] << 8) | receivedData[14];
unsigned int potassium = (receivedData[15] << 8) | receivedData[16];
moist = (soilHumidity / 10.0);
// temp = soilTemperature;
ec = (soilConductivity / 1000.0);
pH = (soilPH / 10.0);
nitroValue = (nitrogen / 1000.0 * 10.0);
phosValue = (phosphorus);
potas = (potassium / 1000.0 / 39.0983 * 100.0);
// Serial.print("Nitrogen");
// Serial.println(nitroValue);
// Serial.print("Phosphorus:");
// Serial.println(phosValue);
// Serial.print("Potassium");
// Serial.println(potas);
// Serial.print("EC");
// Serial.println(ec);
// Serial.print("PH");
// Serial.println(pH);
// Serial.print("Moisture");
// Serial.println(moisture);
delay(5000);
int n = static_cast<int>(nitroValue * 100);
int p = static_cast<int>(phosValue * 100);
int k = static_cast<int>(potas * 100);
int h = static_cast<int>(pH * 100);
int e = static_cast<int>(ec * 100);
int m = static_cast<int>(moist * 100);
nitrogen[6] =highByte(n);
nitrogen[7] =lowByte(n);
dwinSerial.write(nitrogen,8);
phosphorus[6] =highByte(p);
phosphorus[7] =lowByte(p);
dwinSerial.write(phosphorus,8);
potassium[6] =highByte(k);
potassium[7] =lowByte(k);
dwinSerial.write(potassium,8);
phlevel[6] =highByte(h);
phlevel[7] =lowByte(h);
dwinSerial.write(phlevel,8);
electrical[6] =highByte(e);
electrical[7] =lowByte(e);
dwinSerial.write(electrical,8);
moisture[6] =highByte(m);
moisture[7] =lowByte(m);
dwinSerial.write(moisture,8);
can anyone help me in my code I am using DWIN DGUS lcd display , its working perfectly but the mositure,pH,phosphorus is not showing only nitrogen potassium and ec but if i comment this out the other three is showing then. can you help me with the code thanks.
