DWM 3000 - Collaborative Group
Hello, Did anyone successfully manage to use ESP32 DW3000 board with iOS and interact with the U1 chip. As I understand the Makerfabs don't have any examples on how to do it nor they have any supporting libs to do it. Pleases feel free to correct me if I am wrong(I hope to be wrong :slight_smile: ).
Yep I am also looking for a U1 to Makerfabs example.
Estimote provide an example IoS UWB app with an SDK to integrate their UWB product into your own IoS apps. The Estimote UWB beacons uses a DW3210 chip, which is a variant of the Qorvo chip used in the Makerfabs ESP32 UWB DW3000.
I believe that both chips use identical communication schemes. So in theory one should be able to provide clues to working with the other. Meaning that we should be able to create an example IoS app that connects to the Makerfabs DW3000 board.
Useful links:
There is also this. But I have not looked at it.
Hope this helps ... If anyone makes any progress please share ...
Also it looks like Apple is going to move from a 2 antenna U1 chip which provides an azimuth and distance, to a single antenna chip (in the iPhone 14) which does not provide the azimuth .. only giving us distance, which is a shame ... I presume its to do with security / stalking issues with the Airtag ... But who outside of Apple really knows!!?!
Is there any way to send data from one DW3000 to another one, for example, I want to hook it up with a temperature sensor and wants to transmit the data using DW3000.
Has anyone used this one?
Hi Yannick,
Do you have ever built code for Double Sided TWR? I have seen and tried your code for Single Sided TWR using ESP32 DW3000 UWB. It works very well. However, I have another requirement to operate the double-sided TWR method. Actually, I need it for applying the RTLS methods using PyTurtle.
Sincerely,
Theophilus Ezra
Hello everyone. Has anyone used the DWM3000 for TDoA? I have a few questions.
Hy, i am also very interested in the Arduino library you developed. Are there any updates since last year? Please pm me with some information, its still hard to find libraries for this.
Hi, i am also very interested for the code. Could you send me the code via Mail to j.eigner@mci4me.at
Thanks!
Johannes
Hello. Can you see any source code about TDOA?
2024: Did anyone get this working yet? I am trying to use both DWS1000 and DWM3000EVB on the Arduino Uno
