DWM1000 or DWM3000 multiple anchors and tags usage
Is there anyone who can use multiple anchors and tags with the dwm1000 or dwm3000 module? The libraries I found on the internet do not fully provide this. I wonder if anyone has any suggestions? For example, how can we realize a system for 4 anchors and 4 tags? Thanks for your support.
Check whether the commercial products sold by Qorvo (the company that makes the UWB modules) support such multiple tag options. If so, perhaps you can download their SDK.
Actually the Qorvo system support multiple options. However I need a library for modules to use microcontroller. Do you know any library for this?
Contact Qorvo about getting their library.
I have the same issue. I am working on a project that consists of 2 DWM1000s connected to an Arduino Mega as anchors and 1 DWM1000 connected to an Arduino UNO as a tag. I accomplished connection between 1 DWM1000 to another but I failed on this one. @asddsa11 If you have any progress can you help?
If you share the code, I can try the fixed it. Maybe you can wrong in the code.
I'm not entirely sure if the problem would be solved with Qorvo's library. There doesn't seem to be an issue with their own GUI. Also, I think if the problem could be solved with their library, someone would have tried it already.
If multiple tags work for Qorvo, their library does indeed solve the problem.
Were you able to obtain the library?
Hello. I couldn't reach the library. Usually, when I ask a question, they direct me to forums. Have you tried reaching out before?
Post on the Qorvo forum, and ask for the library.
I emailed them directly but they said that they can't offer personalized support to students due to high demand.
Hello. Did you ask for the library?
Yes, I asked for the library and corresponding library. Did you manage to get 2 DWM1000s working on a single Arduino?
Were you given access to the code?
Unfortunately, no.
You should use 2 arduino to connect all pins.
