Hello, everyone! At the moment I am working with Arduino Leonardo and i have a such a non-standard question - is it possible in principle to implement a Dynamic USB HID device descriptor based on Arduino (for example, Leonardo)? I saw the following code on the Internet, where the HID descriptor is described as below:
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x30, // USAGE (X)
0x09, 0x31, // USAGE (Y)
0x09, 0x38, // USAGE (Wheel)
#ifdef ABSOLUTE_MOUSE_MODE
0x15, 0x01, // LOGICAL_MINIMUM (1) <<<< This allows us to talk to any display resolution
0x25, 0x64, // LOGICAL_MAXIMUM (100) <<<< as though it was 100x100 pixels
0x75, 0x08, // REPORT_SIZE (8)
0x95, 0x03, // REPORT_COUNT (3)
0x81, 0x02, // INPUT (Data,Var,Abs) <<<< This allows us to moveTo absolute positions
#else
0x15, 0x81, // LOGICAL_MINIMUM (-127)
0x25, 0x7f, // LOGICAL_MAXIMUM (127)
0x81, 0x06, // INPUT (Data,Var,Rel)
#endif
0xc0, // END_COLLECTION
, where depending on ABSOLUTE_MOUSE_MODE the descriptor will be different on each start. However, I would like to understand how from the outside you can affect this part of the code, to make a descriptor change on the next reboot of the device. The simplest solution, as for me, would be to keep track of some PIN and if it closure to a ground, depending on that, apply the condition and change the Discriptor. I would like to ask knowledgeable people whether it is possible to implement this in principle. I will also clarify that the PIN of the board may not necessarily act as a trigger, the main thing is that the user himself can set it. Thanks!
