Dynamic Variable Names Through Function
Hi All,
I have some code below that reads a push switch and registers the change.
I have the appropriate variables set up for 16 switches:
lastState_fs1, lastState_fs2 etc
outgoingTransmissionData.loopState_1, outgoingTransmissionData.loopState_2 and so on.
Obviously I can just copy and paste the code and change the switch number on each variable.
However it would be nice if I could wrap that up as a function rather than repeat it over and over for each of the 16 switches. eg
void readFootswitch(int switchNumber) {...........}
Is it possible to append a variable name?
eg lastState_fs(switchNumber)
bool fs(switchNumber)Read = digitalRead(footswitch_(switchNumber)_pin);
Cheers
Steve
bool fs1Read = digitalRead(footswitch_1_pin);
if (fs1Read == LOW) {lastState_fs1 = LOW; }
//filter out any noise by setting a time buffer
if ( (millis() - lastDebounceTime) > debounceDelay ) {
//if the button has been pressed
if ( fs1Read == HIGH && lastState_fs1 == LOW) {
  lastState_fs1 = HIGH;
  if (outgoingTransmissionData.loopState_1 == true) {
      outgoingTransmissionData.loopState_1 = false;
      } else if (outgoingTransmissionData.loopState_1 == false) {
          outgoingTransmissionData.loopState_1 = true;
  dataChanged = true;
  lastDebounceTime = millis(); //set the current time
Variable names don't exit after you program is compiled. This sounds like a job for an array.
Something like this:
  bool fsRead = digitalRead(FootSwitchPins[switchNumber]);
  if (fsRead == LOW)
    LastState_fs[switchNumber] = LOW;
  if ( (millis() - LastDebounceTime) > debounceDelay )
    if (fsRead == HIGH && LastState_fs[switchNumber] == LOW)
      LastState_fs[switchNumber] = HIGH;
      if (outgoingTransmissionData.loopState[switchNumber] == true)
        outgoingTransmissionData.loopState[switchNumber] = false;
        outgoingTransmissionData.loopState[switchNumber] = true;
      dataChanged = true;
      LastDebounceTime = millis(); //set the current time
Many thanks.
Steve
