dynamicly define option # in different menu #
Hello there, I'm stuck in finding my way how to do the following. With a button I can do the following: pressing it short = changing an option within a menu pressing it long = changing between menu's.
So now I need to define menu1 has 2 options, menu2 has 3 option, and menu3 = 6 options. and of course add some actions to the choice I've made.
I'm a bit green when it gets deep in arrays and how to use them this way. I only know the basic how to put information in an array and how to read a value from an array nr.
If someone could give me a hand ;) Maybe I'm looking in a wrong direction and don't have to use arrays.
I was thinking: int menu[] = {2, 3, 6}; but how to increment the option when in the selected menu....
Thanx!
It's great when you type, you think.. And just when I pressed send I came up with my own answer:
// CHANGE OPTION - START
int option_switch() {
if (my_option == menu[my_menu] )
        my_option = 1;     // if you are at the last menu, go back to the initial menu number
increase_option_number:
        my_option ++;      // increase the menu number if it's not allready at max.
  Serial.print("Changing to option nr: ");
  Serial.print(my_option);
  Serial.print("\n");
// CHANGE OPTION - STOP
// CHANGE MENU - START
int menu_switch(){
if (my_menu == 2)      // I only defined 2 menu's, you can add more by increasing this my_menu number)
        my_menu = 1;     // if you are at the last menu, go back to the initial menu number
increase_menu_number:
        my_menu ++;      // increase the menu number if it's not allready at max.
  Serial.print("Changing to menu nr: ");
  Serial.print(my_menu);
  Serial.print("\n");
// CHANGE MENU - STOP
