dynamixel AX12 on UNO library
Hi all,
i'm trying to use a servo AX12A on my arduino UNO using the savage electronics library.
I'm trying to find out what's wrong with my libraries since i can't seem to be able to upload the program to my arduino.
I'm using the example that comes with the library "DynamixelSerial":
#include <DynamixelSerial.h>
void setup(){
Dynamixel.begin(1000000,2);  // Inicialize the servo at 1Mbps and Pin Control 2
void loop(){
  Dynamixel.move(1,random(200,800));  // Move the Servo radomly from 200 to 800
  Dynamixel.moveSpeed(1,random(200,800),random(200,800));
  delay(2000);
  Dynamixel.setEndless(1,ON);
  Dynamixel.turn(1,RIGTH,1000);
  delay(3000);
  Dynamixel.turn(1,LEFT,1000);
  delay(3000);
  Dynamixel.setEndless(1,OFF);
  Dynamixel.ledStatus(1,ON);
  Dynamixel.moveRW(1,512);
  Dynamixel.action();
  Dynamixel.ledStatus(1,OFF);
and i get the error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xff
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
I read in a comment section of the savageelectronics blog that you have to add the softwareserial library to the sketch folder, and when i do that i get the following error:
Se encontraron múltiples librerías para "SoftwareSerial.h"
Usado: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
No usado: C:\Users\Albert\Documents\Arduino\libraries\SoftwareSerial
exit status 1
conflicting declaration 'char SoftwareSerial::_receive_buffer [64]'
Multiple SoftwareSerial libs were found, it uses the one in the core IDE files and not the one i should be using (i think).
Anyone has used these libraries before and can help out please?
thank you
That comment was rubbish. Before you did that, the code compiled but was not properly uploaded to the Arduino.
That guide has a list of steps to follow. Which step is "Complain on forum, in wrong section"?
