Hello,
I am trying to control a DYNAMIXEL MX-106R servo with no luck.
It uses the RS485 Asynchronous Serial Communication protocol and therefore a MAX485 TTL to RS-485 Module is used to allow the arduino mega to communicate with the servo.
The design and code are taken from this post which uses the same protocol but a different servo.
I run the code below but it does not do anything and there is no indication that the arduino mega is communicating with the servo.
Has anyone done this before or know of any librarys that will work.
Setting the ID
byte servoID_1 = 0x00;
void setup(){
pinMode(2,OUTPUT);
Serial3.begin(57143);
Serial.flush();
void loop(){
moveServo(servoID_1, 200); // Move to position 200
moveServo(servoID_1, 500); // Move to position 500
void moveServo(byte servoID, int Position){
char Position_H = Position >> 8; //same as /256 and truncating
char Position_L = Position % 256;
byte notchecksum = ~lowByte(servoID + 0x05 + 0x03 + 0x1E + Position_L + Position_H);
digitalWrite(2,HIGH); // put MAX485 into transmitting mode
delay(1);
Serial3.write(0xFF); // Start bytes
Serial3.write(servoID); // Servo ID
Serial3.write(0x05); // Length of message (2 + 3 parameters)
Serial3.write(0x03); // Write
Serial3.write(0x1E); // Parameter 1
Serial3.write(Position_L); // Parameter 2
Serial3.write(Position_H); // Parameter 3
Serial3.write(notchecksum); // notCheckSum
Serial3.flush(); // for good measure
digitalWrite(2,LOW); // put MAX485 back into receiving mode
delay(1);
This should set the ID of the servo which is important to comunicate with it.
Moving the servo
void setup(){
pinMode(2,OUTPUT);
Serial.flush();
void loop(){
delay(1);
delay(1);
This code should move the servo but it is not doing anything?
