Hello, I had a bit of help with this in the Robotis forum but wanted to post here as well to cast a wider net, see if there are any silver bullets out there.. I’m trying to make a 2-axis system using the parts listed below, but I’m struggling to get it off the ground. I have
- 2x XL-320 motors (XL-320)
- OpenCM9.04 board, connected to PC via USB (OpenCM 9.04)
- Arduino IDE v1.8.13
- OpenCM9.04 boards package v1.5.1 (GitHub - ROBOTIS-GIT/OpenCM9.04: Software for OpenCM 9.04 / OpenCM means Open-source Control Module.)
- Dynamixel2Arduino library v0.5.1 (GitHub - ROBOTIS-GIT/Dynamixel2Arduino: DYNAMIXEL protocol library for Arduino)
- 7.4V power supplied
I can’t seem to move any motors, or even detect any motors connected - the “scan_dynamixel” example from the Dynamixel2Arduino library says 0 dyanmixels found, and none of the other examples appear to function at all. It'll happily upload sketches and use the serial monitor FWIW.
Worth noting that I have seen this board and these motors all working using the legacy "OpenCM" IDE from dynamixel (which doesn't appear to support controlling multiple motors, hence the switch to real arduino)
Please help me turn this on? Thanks!
Sean
Setup pic, just in case (I know the output is off and a motor disconnected)
That example, for example:
* Copyright 2016 ROBOTIS CO., LTD.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include <Dynamixel2Arduino.h>
// Please modify it to suit your hardware.
#if defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_MEGA2560) // When using DynamixelShield
#include <SoftwareSerial.h>
SoftwareSerial soft_serial(7, 8); // DYNAMIXELShield UART RX/TX
#define DXL_SERIAL Serial
#define DEBUG_SERIAL soft_serial
const uint8_t DXL_DIR_PIN = 2; // DYNAMIXEL Shield DIR PIN
#elif defined(ARDUINO_SAM_DUE) // When using DynamixelShield
#define DEBUG_SERIAL SerialUSB
#elif defined(ARDUINO_SAM_ZERO) // When using DynamixelShield
#define DXL_SERIAL Serial1
#elif defined(ARDUINO_OpenCM904) // When using official ROBOTIS board with DXL circuit.
#define DXL_SERIAL Serial3 //OpenCM9.04 EXP Board's DXL port Serial. (Serial1 for the DXL port on the OpenCM 9.04 board)
const uint8_t DXL_DIR_PIN = 22; //OpenCM9.04 EXP Board's DIR PIN. (28 for the DXL port on the OpenCM 9.04 board)
#elif defined(ARDUINO_OpenCR) // When using official ROBOTIS board with DXL circuit.
// For OpenCR, there is a DXL Power Enable pin, so you must initialize and control it.
// Reference link : https://github.com/ROBOTIS-GIT/OpenCR/blob/master/arduino/opencr_arduino/opencr/libraries/DynamixelSDK/src/dynamixel_sdk/port_handler_arduino.cpp#L78
const uint8_t DXL_DIR_PIN = 84; // OpenCR Board's DIR PIN.
#else // Other boards when using DynamixelShield
#endif
#define MAX_BAUD 5
const int32_t buad[MAX_BAUD] = {57600, 115200, 1000000, 2000000, 3000000};
Dynamixel2Arduino dxl(DXL_SERIAL, DXL_DIR_PIN);
//This namespace is required to use Control table item names
using namespace ControlTableItem;
int8_t index = 0;
int8_t found_dynamixel = 0;
// Use UART port of DYNAMIXEL Shield to debug.
DEBUG_SERIAL.begin(115200); //set debugging port baudrate to 115200bps
while(!DEBUG_SERIAL); //Wait until the serial port is opened
for(int8_t protocol = 1; protocol < 3; protocol++) {
// Set Port Protocol Version. This has to match with DYNAMIXEL protocol version.
dxl.setPortProtocolVersion((float)protocol);
DEBUG_SERIAL.print("SCAN PROTOCOL ");
DEBUG_SERIAL.println(protocol);
for(index = 0; index < MAX_BAUD; index++) {
// Set Port baudrate.
DEBUG_SERIAL.print("SCAN BAUDRATE ");
DEBUG_SERIAL.println(buad[index]);
dxl.begin(buad[index]);
for(int id = 0; id < DXL_BROADCAST_ID; id++) {
//iterate until all ID in each buadrate is scanned.
if(dxl.ping(id)) {
DEBUG_SERIAL.print("ID : ");
DEBUG_SERIAL.print(id);
DEBUG_SERIAL.print(", Model Number: ");
DEBUG_SERIAL.println(dxl.getModelNumber(id));
found_dynamixel++;
DEBUG_SERIAL.print("Total ");
DEBUG_SERIAL.print(found_dynamixel);
DEBUG_SERIAL.println(" DYNAMIXEL(s) found!");
