Dynamixel Workbench library
Hello,
I am new to Arduino programming and currently working on a project, to build a mars rover with OpenCR1.0 board and XL430 dynamixels. I am using the dynamixel SDK and workbench library and I am finding it difficult to understand the code. I face few issues with uploading code to the board and somehow solved it.
But now the problem is the board functions fine if I use the example files and board gives a usb not recognized error if I upload a code that created. I have attached the code which causes the error. Could you please check the code and point out is there a problem in the code.
Someone please explain what does *log in the codes used in dynamixel workbench library.
Hoping to get information from guys with some experience.
Thanks a lot
wheel_mode.ino (772 Bytes)
Please post your code in code tags and not as an attachment...Learn how to get the best out of this forum...
OP's wheel_mode.ino sketch:
#include <DynamixelWorkbench.h>
#include<Dynamixel2Arduino.h>
#if defined(__OPENCM904__)
#define DEVICE_NAME "3" //Dynamixel on Serial3(USART3)  <-OpenCM 485EXP
#elif defined(__OPENCR__)
#define DEVICE_NAME ""
#endif
#define BAUDRATE  57600
#define DXL_ID    10
DynamixelWorkbench dxl;
Dynamixel2Arduino dx1A;
  Serial.begin(57600);
  const char *log;
  uint8_t dxl_id = DXL_ID;
  //dxlA.torqueOn(DXL_ID);
  //dxl.wheelMode(DXL_ID, 0, &log);
  dxl.goalVelocity(dxl_id, (int32_t) - 100);
  delay(3000);
  dxl.goalVelocity(dxl_id, (int32_t)0);
The log in the code above is basically a null statement. it is a part of the Dynamixel workbench and you can find out more about the workbench on the Robotis eManual.
If you are having a lot of difficulties you can also contact their customer support CS@robotis.com or post an issue to their Github page they are pretty responcive.
