DynDNS Arduino - Not updating the IP
Why this code does not work? Not updating the IP.
Arduino Uno Rev3 + Ethernet W5100
/* DynDNS
 created 2011
 by Boris Landoni
 This example code is in the public domain.
 http://www.open-electronics.org
 http://www.futurashop.it
//http://username:password@members.dyndns.org/nic/update?hostname=yourhostname&myip=ipaddress
#include <Ethernet.h>
//#include <EthernetDNS.h>
#include <WString.h>
#include <EEPROM.h>
#include <SPI.h>
#define UPDATE_INTERVAL            30000    // if the connection is good wait 30 seconds before updating again - should not be less than 5
int ledR =  8;
int ledG =  9;
unsigned long pubblica=0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 3, 12 };
byte domainaddrip[]= { 208, 78, 70, 70 }; //http://checkip.dyndns.com/
byte ipAddr[4];
byte domaindydns[]= { 204, 13, 248, 112 }; // members.dyndns.org
char hostname[ ]   = "xxxxxxxxxxx";
char userpwdb64[ ] = "xxxxxxxxxxxx";  //http://www.functions-online.com/base64_encode.html    use->   username:password
String ipadsl     = String(20);
String ipadslold  = String(20);
String inString   = String(51);
//Client client(server, 80);
const char* ip_to_str(const uint8_t*);
//void nameFound(const char* name, const byte ipAddr[4]);
EthernetClient client;
EthernetClient clientdyn;
  pinMode(ledR, OUTPUT);
  pinMode(ledG, OUTPUT);
  Ethernet.begin(mac, ip);
  //EthernetDNS.setDNSServer(dnsServerIp);
  Serial.println("*****************************************Start***************************************************");
  //risolviip();
  //delay(1000);
  if (millis() < pubblica) pubblica = millis();
      if ((millis() - pubblica) > UPDATE_INTERVAL){
          //Serial.print("Passati ");
          //Serial.print(UPDATE_INTERVAL);
          //Serial.println(" ms");
          Serial.print("tempo trascorso dall'accensione ");
          Serial.println(millis());
          Serial.println(pubblica);
          acquisisciip();
void acquisisciip()
  int timeout=0;
  int skip=0;
  ipadsl="";
  inString="";
  digitalWrite(ledG, HIGH);
  Serial.print("connecting to ");
  //Serial.print(domain);
  //Serial.print(" = ip ");
  //Serial.println(ip_to_str(domainaddrip));
  if (client.connect(domainaddrip, 80)) {
    Serial.println("connected");
    client.println("GET / HTTP/1.0");
    //client.println("GET / HTTP/1.0");
    client.print("HOST: ");
    client.println("www.dyndns.com");
    //client.println(ip_to_str(domainaddrip));
    client.println();
    Serial.println("connection failed");
  while (!client.available() && timeout<50)
    timeout++;
    Serial.print("Time out ");
    Serial.println(timeout);
    delay(100);
  while (client.available())
      //Serial.println("client.available");
      //if (client.available())
        char c = client.read();
        //Serial.print(c);
        skip++;
        if (skip>220)
          if ((inString.length())<50) inString.concat(c);
  client.flush();
      if ((inString.length())>5)
          //Serial.print("inString: ");
          //Serial.println(inString);
          if (inString.equalsIgnoreCase("Address"))
              int from=(inString.indexOf("Address")+9);
              int lunghe=inString.length();
              int to=(lunghe-16);
              /*Serial.print("Lunghezza instring    = ");
              Serial.println(lunghe);
              Serial.print("Posizione address + 9 = ");
              Serial.println(from);
              Serial.print("Posizione fine   - 16 = ");
              Serial.println(to);
              //strcpy(ipadsl,(inString.substring((inString.indexOf("Address")+9),(inString.length()-16))));
              ipadsl=inString.substring(from,to);
              //Serial.print("Lunghezza ipadsl      = ");
              //Serial.println(ipadsl.length());
              Serial.print("IP rilevato dal sito: >");
              Serial.print(ipadsl);
              Serial.println("<");
   if (!client.connected())
        Serial.println("disconnecting.");
        client.stop();
        delay (1000);
        Serial.print("lunghezza IP ");
        //Serial.println(strlen(ipadsl));
        if (((ipadsl))!=0)
              Serial.print("IP nuovo  : >");
              for (int i=0; i<(ipadsl.length()); i++) {    //salva in memoria l'indirizzo acquisito
                ipadslold[i] = EEPROM.read(i);
                //Serial.print("carattere  : >");
                //Serial.print(ipadslold[i]);
                //Serial.println("<");
              Serial.print("IP vecchio: >");
              Serial.print(ipadslold);
              if ((ipadsl,ipadslold))
                Serial.println("IP diverso PUBBLICO");
                  digitalWrite(ledR, HIGH);
                pubblicaip();
                  digitalWrite(ledR, LOW);
                Serial.println("IP uguale");
                digitalWrite(ledG, LOW);
              //ipadslold="";
              //ipadslold.append(ipadsl);
              //ipadslold="";
              //Serial.print("IP vecchio azzerato: >");
              //Serial.print(ipadslold);
              //strcpy(ipadslold,ipadsl);
                EEPROM.write(i, ipadsl[i]);
void pubblicaip()
  int timeout=0;
  Serial.println(ip_to_str(domaindydns));
  Serial.print("IP da pubblicare ");
  Serial.println(ipadsl);
if (clientdyn.connect(domaindydns, 80)) {
    clientdyn.print("GET /nic/update?hostname=");
    clientdyn.print(hostname);
    clientdyn.print("&myip=");
    clientdyn.print(ipadsl);
    clientdyn.println(" HTTP/1.0 ");
    //clientdyn.println("Host: members.dyndns.org ");
    clientdyn.print("Host: ");
    clientdyn.println(ip_to_str(domaindydns));
    clientdyn.print("Authorization: Basic ");
    clientdyn.println(userpwdb64);
    clientdyn.println("User-Agent: futura - arduinodydns - 1.1");
    clientdyn.println();
 //   delay(3000);
  while (!clientdyn.available() && timeout<50)
    timeout++;
    delay(100);
  while (clientdyn.available())
      if (clientdyn.available())
        char c = clientdyn.read();
        Serial.print(c);
  if (!clientdyn.connected())
        clientdyn.stop();
// This is just a little utility function to format an IP address as a string.
const char* ip_to_str(const uint8_t* ipAddr)
  static char buf[16];
  sprintf(buf, "%d.%d.%d.%d\0", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
  return buf;
Go read the documentation on the String class, and tell us why you need to initialize ipadsl to "20". Ditto for the other instances.
There is no reason to be using the String class at all.
What do your (commented out) Serial.print()s tell you is happening?
The code is not in error when uploading to the Arduino. But it is not updating the DynDNS site.
The Serial.print (monitor) appears "**************************************Start************************************************"
How is it possible for millis() to return a value less than pubblica? The pubblica variable starts at 0, so millis() will not be less than 0. When the UPDATE_INTERVAL time has passed, pubblica is updated to when the event occurred. The millis() function can never return a value that is less than what it returned last time, unless you have installed it in Rocky and Bullwinkle’s way back machine. Therefore, that first statement will NEVER evaluate to true.
Perhaps you need to uncomment some of the commented out Serial.print() statements, to see why nothing beyond the setup() statement is executed.
