e-Drums! PCM audio simultaneous samples
Hi bro...! I'm new to Arduino!! Currently using uno...Im.doin a project on Arduino drums! I successfully built a midi drums.
.now try to upgrade to e drum..I fetched the audio samples into the Arduino Uno..
Used piezo sensor as input ..getting output thr 11
PCM library
(https://github.com/damellis/PCM/zipball/master)
When I hit one piezo i can able to hear the sound..but when I hit two piezo simultaneously..(.I.e kick and hats at same time )o I can't able to hear the both sound same time...struggling alot n this issue.I googled ,but n't able to find a solution...plz help me to fix the problem...
Fetching sample to Arduino
Code example;-
Void loop(){
If { piezo 1 > 100)
startPlayback( sample 1);
If { piezo 2> 100)
startPlayback( sample 2);
Yes most Arduino sample players can only output one sound at a time.
