[E][esp32-hal-i2c.c:161] i2cWrite(): Busy Timeout! Addr: 44
i am working on esp32 with SHT30 temperature sensor, after 2 hour or 3 hour getting issue like
here is my code:
-> Initialised clock and Wire Begin here:
** Wire.begin(21,22);**
** Wire.setTimeout(500);**
** Wire.setClock(100000);**
->function to get i2c data
void get_i2c_data(){
unsigned int data[6]; **
** // Start I2C Transmission
** Serial.println("----------------------Begin 1TXtion");**
** Wire.beginTransmission(I2CAddr);**
** Serial.println("----------------------Begin 2TXtion");**
** // Send measurement command**
** Wire.write(0x2C);**
** Wire.write(0x06);**
** delay(500);**
** // Stop I2C transmission**
if (Wire.endTransmission(true)!=0) {
** Serial.println("----------------------Faild to end TXtion");**
** // return; **
** delay(500);**
** // Request 6 bytes of data**
//Serial.print("I2C state");
// Serial.println( Wire.requestFrom(I2CAddr, 6));
if(Wire.requestFrom(I2CAddr, 6) == 6){
** Serial.println("-------------------------------Reading i2c address");**
** // Read 6 bytes of data**
** // cTemp msb, cTemp lsb, cTemp crc, humidity msb, humidity lsb, humidity crc**
** if (Wire.available() == 6)**
** { temp_available = 1;**
** data[0] = Wire.read();**
** data[1] = Wire.read();**
** data[2] = Wire.read();**
** data[3] = Wire.read();**
** data[4] = Wire.read();**
** data[5] = Wire.read();**
** else{**
** temp_available = 0;**
** if (Wire.available()!=0) {**
** Serial.println("----------------------i2c Not available");**
** return;**
** Serial.printf("Hex Temp: %x, %x, %x,%x, %x, %x\r\n",data[0],data[1],data[2],data[3],data[4],data[5]);**
__ float cTemp = ((((data[0] << 8) | data[1]) * 175) / 65535.0) - 45;__
** Serial.printf("VTemp");**
** Serial.println(cTemp);**
** temperature_fromSensor_celcius = (cTemp - 4);**
float temp_Farenheit = (temperature_fromSensor_celcius * 1.8) + 32;
temperature_fromSensor = (temperature_fromSensor_celcius * 1.8) + 32;
float humidity_sens = ((((data[3] << 8) | data[4]) * 100) / 65535.0) + 10;
humidity_fromSensor = ((((data[3] << 8) | data[4]) * 100) / 65535.0);
** humidity_fromSensor = humidity_fromSensor + 10;**
I even tried to use Wire.reset() function when i got this issue but still no use. please help me to solve this.
how to solve this issue
I reckon it's one of those grinning fools in dark glasses.
See How to use the Forum
...R
Busy is telling you that SDA or SCL is not Idle, Something is holding them low.
you can use
uint32_t timeout=millis();
while(Wire.busy()&&(millis()-timeout<1000));
To wait for the bus to clear, or you can force a reset with
if(Wire.busy()) Wire.begin();
Your choice.
