I need to programm arduino and read signal from four straungauge base sensors sample @ 10 KHZ. About 5-6 mS between mesurements.
Topic: The aim is to make a goal that can measure the speed and accuracy of a ball landing on it. A suggestion of implementation is to make straingauge based sensors and interface them to an Arduino board.
I have Arduino Uno, it is possible to sample at this high freq right?
How can I transfer mesurments to EXEL or MATLAB?
You can send the values to any PC over a serial port. Capture the data with a terminal like putty.exe
This code should get your started
unsigned long lastTime = 0;
while (micros() -100 < lastTime);
lastTime = micros();
unsigned long value = analogRead(A0); // to be replaced by fast analogRead
Serial.write(value);
Can u please help me?
just did, now it is your turn to make the next step.
