Hello from Barcelona.
I’ve two cats and for me it’s hard sometimes to remember when I’ve cleaned their cat litters.
Instead of putting a post-it with the last date, I decided to do something more fancy:
As I have an e-ink Waveshare display I tried to create a device that, clicking a simple push-button would keep on-screen the date when I cleaned the cat’s litter.
The idea was that the display would keep the last date without the need for electricity until the next use.
For my setup, I tried with an Arduino Nano, the e-ink display and a DS3231 RTC.
Thanks to ZinggJM I was able to print on screen a static text, but trying to get the date from the screen and the time form the DS3231 didn’t work. I searched in the forum and there was another guy with a similar problem. (It look like that both the screen and the RTC module were using the I2C channel).
I tried to store the date, stop the RTC and then print on the screen, but I didn’t find any way of doing it.
In any case, including the e-ink display libraries and an array with the name of the days and the months the sketch couldn’t be uploaded to a single Arduino Nano due to the lack of free memory.
So the final setup was to use 2 Arduinos Nano: one for the Real-Time Clock that will send the data to the main Arduino via Serial. And the main Arduino will print it in the e-ink display.
My wiring at the moment looks like this:
(As I needed more GND pins, I have used the ones from the ICSP, I hope that it is correct in case of need)
I decided that I do not want to keep the push-button pressed until the whole thing ends, so I have added the relay module to keep the system on until it ends.
The code that I send to the RTC Arduino (Number 2 in the image) is:
#include <Wire.h>
#include "RTClib.h"
RTC_DS3231 rtc;
// I'm going to declare two arrays with the name of the days and the names of the months.
// As I should clean the litters, at least twice a week
// I'm not interested into getting the day of the month number instead of the name of the day in the week
String daysOfTheWeek[7] = { "SUNDAY", "MONDAY", "TUESDAY", "WEDNESDAY", "THURSDAY", "FRIDAY", "SATURDAY" };
String monthsNames[12] = {"FEBRUARY", "MARCH", "APRIL", "MAY", "JUNE", "JULY","AUGUST","SEPTEMBER","OCTOBER","NOVEMBER","DECEMBER","JANUARY" };
int monthNumber = 1;
String currentDate = "";
String currentDay = "";
delay(4000); // I'm giving it some time before it does starts sending things to the main Arduino
Serial.begin(115200); // I've tried with bigger baud rates, and it eventually worked 1 of every 20 times
if (!rtc.begin()) {
while (1);
if (rtc.lostPower()) {
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void printDate(DateTime date)
monthNumber = (date.month(), DEC) - 1;
currentDay = (date.day(), DEC);
currentDate = currentDay + " " + (monthsNames[monthNumber]); //I create a string with the current day + the month name
Serial.print(daysOfTheWeek[date.dayOfTheWeek()]);
Serial.print("\n");// I also add this line break charachter for the screen
Serial.print(date.day(), DEC);
Serial.print(" ");
Serial.println(monthsNames[monthnumber]);
// Get the current date and send it via Serial
DateTime now = rtc.now();
printDate(now);
delay(2000);
If I open the serial it sends me correctly the data.
The code for the main Arduino is this one:
#include <string.h>
#include <GxEPD.h>
#include <GxGDEH029A1/GxGDEH029A1.h> // 2.9" b/w
#include <GxIO/GxIO_SPI/GxIO_SPI.h>
#include <GxIO/GxIO.h>
#include <Fonts/FreeMonoBold12pt7b.h>
#include <Fonts/FreeMonoBold24pt7b.h>
// constructor for AVR Arduino, copy from GxEPD_Example else
GxIO_Class io(SPI, /*CS=*/ SS, /*DC=*/ 8, /*RST=*/ 9); // arbitrary selection of 8, 9 selected for default of GxEPD_Class
GxEPD_Class display(io, /*RST=*/ 9, /*BUSY=*/ 7); // default selection of (9), 7
String currentDate;
pinMode(3, OUTPUT);
digitalWrite(3, LOW); //I turn the realy pin on, so now there's no need to keep the push button pressed
delay(2000);
display.init();
display.eraseDisplay(); //This works fine beacuse the screen flashes.
pinMode(4, OUTPUT);
digitalWrite(4, HIGH); //With this instruction I turn the second Arduino on.
void drawHelloWorld()
display.fillScreen(GxEPD_WHITE);
display.setTextColor(GxEPD_BLACK);
display.setFont(&FreeMonoBold12pt7b);
display.setRotation(15);
display.setCursor(0, 15);
display.print("LITTERS CLEANED:");
display.setCursor(0, 70);
display.setFont(&FreeMonoBold24pt7b);
display.print(currentDate);
delay(10000); // I give it some time to update the e-ink display
digitalWrite(3, HIGH); //Finally I turn down the whole system desactivating the relay
void drawHelloWorld0() // If I call this function as a welcome screen, it always works
display.fillScreen(GxEPD_BLACK);
display.setTextColor(GxEPD_WHITE);
display.setCursor(0, 25);
display.print(" _/)\n (^.^) MIU\n MIU");
display.setCursor(37, 25);
display.print("/)");
display.setCursor(58, 100);
display.print(">^<");
display.setCursor(15, 120);
display.print("( )");
while (Serial.available()) {
currentDate= Serial.readString();
delay(3);
if (currentDate.length() > 5) { //just a little checking to see if the is longer that a simple char
display.drawPaged(drawHelloWorld); // version for AVR using paged drawing, works also on other processors
This code also claims that there is no so much free memory available (90% used).
The firsts test with the Arduinos plugged via USB to the computer worked 1 of 20 times.
I honestly don’t know what I’m doing wrong. I guess that there’s something wrong with the serial communication between both Arduinos, but when I click the push button the system starts and there’s a point that the main Arduino disconnects the relay, so it is receiving the data from the second Arduino.
Any help would be truly appreciated.
Greets from Barcelona
