E-ink display memory buffer issue
Dear people on this forum I'm very much struggling with this project of mine.
I'm trying to recreate this project, but rewriting the code to work with a 5.65inch e-paper from waveshare instead. The display does not have any internal memory, it's all comming from the ESP32 Firebeetle 2 i'm using.
I cannot get the E-paper to display the whole thing, only half the screen (running out of memory it seems). Do you have any direction(s) I could take to try and make this work?
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include "epd5in65f.h"
#include <Preferences.h>
#include <algorithm>
#include <vector>
#include "time_utils.h"
//This is the pin for the transistor that powers the external components
#define TRANSISTOR_PIN 26
Preferences preferences;
Epd epd;
unsigned long delta; // Variable to store the time it took to update the display for deep sleep calculations
unsigned long deltaSinceTimeObtain; // Variable to store the time it took to update the display since the time was obtained for deep sleep calculations
#define SD_CS_PIN 22
uint16_t width() { return EPD_WIDTH; }
uint16_t height() { return EPD_HEIGHT; }
SPIClass vspi(VSPI); // VSPI for SD card
// Color palette for dithering
uint8_t colorPallete[7*3] = {
    0, 0, 0,       // Black
    255, 255, 255, // White
    67, 138, 28,   // Green
    100, 64, 255,  // Blue
    191, 0, 0,     // Red
    255, 243, 56,  // Yellow
    232, 126, 0,   // Orange
uint16_t read16(fs::File &f) {
    uint16_t result;
    ((uint8_t *)&result)[0] = f.read(); // LSB
    ((uint8_t *)&result)[1] = f.read(); // MSB
    return result;
uint32_t read32(fs::File &f) {
    uint32_t result;
    ((uint8_t *)&result)[2] = f.read();
    ((uint8_t *)&result)[3] = f.read(); // MSB
    return result;
SET_LOOP_TASK_STACK_SIZE(16384);
    delta = millis();
    Serial.println("Starting setup");
    analogReadResolution(12);
    preferences.begin("e-paper", false);
    esp_sleep_wakeup_cause_t wakeup_reason;
    wakeup_reason = esp_sleep_get_wakeup_cause();
    if(wakeup_reason == ESP_SLEEP_WAKEUP_TIMER) {
        Serial.println("Woke up from deep sleep due to timer.");
        Serial.println("Did not wake up from deep sleep.");
    pinMode(TRANSISTOR_PIN, OUTPUT);
    digitalWrite(TRANSISTOR_PIN, HIGH);
    delay(100); // Increased delay to ensure power stabilizes
    Serial.println("Initializing SD card...");
    while(!SD.begin(SD_CS_PIN, vspi)){
        Serial.println("Card Mount Failed");
        hibernate();
    Serial.println("SD card initialized");
    initializeWifi();
    initializeTime();
    deltaSinceTimeObtain = millis();
    Serial.println("Initializing e-Paper display...");
    if (epd.Init() != 0) {
        Serial.println("e-Paper init failed");
        hibernate();
    Serial.println("e-Paper initialized successfully");
    Serial.println("Clearing display...");
    epd.Clear(EPD_5IN65F_WHITE);
    delay(100);
    checkSDFiles();
    String file = getNextFile();
    drawBmp(file.c_str());
    digitalWrite(TRANSISTOR_PIN, LOW);
    preferences.end();
    hibernate();
void hibernate() {
    Serial.println("Starting deep sleep");
    esp_deep_sleep(static_cast<uint64_t>(getSecondsTillNextImage(delta, deltaSinceTimeObtain))* 1e6);
bool drawBmp(const char *filename) {
    Serial.println("Drawing bitmap file: " + String(filename));
    fs::File bmpFS = SD.open(filename);
    if (!bmpFS) {
        Serial.println("File not found");
        return false;
    // BMP header parsing remains the same...
    uint16_t magic = read16(bmpFS);
    if (magic != ('B' | ('M' << 8))) {
        Serial.println("Not a BMP file");
        bmpFS.close();
        return false;
    read32(bmpFS); // filesize
    read32(bmpFS); // reserved
    uint32_t seekOffset = read32(bmpFS);
    uint32_t headerSize = read32(bmpFS);
    uint32_t w = read32(bmpFS);
    uint32_t h = read32(bmpFS);
    read16(bmpFS); // planes
    uint16_t bitDepth = read16(bmpFS);
    uint32_t compression = read32(bmpFS);
    Serial.print("Image dimensions: ");
    Serial.print(w); Serial.print("x"); Serial.println(h);
    if (compression != 0 || (bitDepth != 24 && bitDepth != 1 && bitDepth != 4 && bitDepth != 8)) {
        Serial.println("Unsupported BMP format");
        bmpFS.close();
        return false;
    // Calculate scaling factors
    float scale_w = 1.0f;
    float scale_h = 1.0f;
    if (w > EPD_WIDTH || h > EPD_HEIGHT) {
        scale_w = (float)EPD_WIDTH / w;
        scale_h = (float)EPD_HEIGHT / h;
        if (scale_w > scale_h) scale_w = scale_h;
        if (scale_h > scale_w) scale_h = scale_w;
    uint32_t new_w = (uint32_t)(w * scale_w);
    uint32_t new_h = (uint32_t)(h * scale_h);
    uint16_t x = (EPD_WIDTH - new_w) / 2;
    uint16_t y = (EPD_HEIGHT - new_h) / 2;
    // Process palette if needed
    uint32_t palette[256];
    if (bitDepth <= 8) {
        read32(bmpFS); read32(bmpFS); read32(bmpFS);
        uint32_t paletteSize = read32(bmpFS);
        if (paletteSize == 0) paletteSize = 1 << bitDepth;
        bmpFS.seek(14 + headerSize);
        for (uint16_t i = 0; i < paletteSize; i++) {
            palette[i] = read32(bmpFS);
    // Allocate half frame buffer
    const uint32_t HALF_HEIGHT = EPD_HEIGHT / 2;
    UBYTE* halfBuffer = (UBYTE*)malloc((EPD_WIDTH * HALF_HEIGHT) / 2);
    if (!halfBuffer) {
        Serial.println("Failed to allocate half buffer");
        bmpFS.close();
        return false;
    uint32_t lineSize = ((bitDepth * w + 31) >> 5) << 2;
    uint8_t* lineBuffer = (uint8_t*)malloc(lineSize);
    if (!lineBuffer) {
        free(halfBuffer);
        bmpFS.close();
        return false;
    int batteryVolts = analogReadMilliVolts(0) * 1.69657;
    // Process image in two halves
    for (int half = 0; half < 2; half++) {
        Serial.printf("Processing half %d of the image\n", half + 1);
        // Clear half buffer
        memset(halfBuffer, EPD_5IN65F_WHITE, (EPD_WIDTH * HALF_HEIGHT) / 2);
        // Calculate start and end Y positions for this half
        int startY = half * HALF_HEIGHT;
        int endY = startY + HALF_HEIGHT;
        // Process this half of the image
        for (int y_pos = startY; y_pos < endY; y_pos++) {
            if (y_pos < y || y_pos >= y + new_h) continue;
            int src_y = (int)((y_pos - y) / scale_h);
            if (src_y >= h) continue;
            uint32_t pos = seekOffset + (h - 1 - src_y) * lineSize;
            bmpFS.seek(pos);
            bmpFS.read(lineBuffer, lineSize);
            for (int x_pos = 0; x_pos < EPD_WIDTH; x_pos++) {
                if (x_pos < x || x_pos >= x + new_w) continue;
                int src_x = (int)((x_pos - x) / scale_w);
                if (src_x >= w) continue;
                uint8_t r, g, b;
                if (bitDepth == 24) {
                    int pixel_offset = src_x * 3;
                    b = lineBuffer[pixel_offset + 0];
                    g = lineBuffer[pixel_offset + 1];
                    r = lineBuffer[pixel_offset + 2];
                    uint32_t c = 0;
                    if (bitDepth == 8) {
                        c = palette[lineBuffer[src_x]];
                    } else if (bitDepth == 4) {
                        c = palette[(lineBuffer[src_x/2] >> ((src_x & 1) ? 0 : 4)) & 0x0F];
                    } else { // bitDepth == 1
                        c = palette[(lineBuffer[src_x/8] >> (7 - (src_x & 7))) & 0x01];
                    b = c;
                    g = c >> 8;
                    r = c >> 16;
                uint8_t color;
                int indexColor = depalette(r, g, b);
                switch (indexColor) {
                    case 0: color = EPD_5IN65F_BLACK; break;
                    case 1: color = EPD_5IN65F_WHITE; break;
                    case 2: color = EPD_5IN65F_GREEN; break;
                    case 3: color = EPD_5IN65F_BLUE; break;
                    case 4: color = EPD_5IN65F_RED; break;
                    case 5: color = EPD_5IN65F_YELLOW; break;
                    case 6: color = EPD_5IN65F_ORANGE; break;
                    default: color = EPD_5IN65F_WHITE; break;
                // Show battery warning if needed
                if (batteryVolts <= 3500 && batteryVolts >= 1000 &&
                    x_pos <= 50 && y_pos >= EPD_HEIGHT-50) {
                // Store in half buffer (adjust y_pos to be relative to current half)
                uint32_t buf_pos = (y_pos - startY) * EPD_WIDTH + x_pos;
                if (buf_pos & 0x01) {
                    halfBuffer[buf_pos >> 1] = (halfBuffer[buf_pos >> 1] & 0xF0) | color;
                    halfBuffer[buf_pos >> 1] = (halfBuffer[buf_pos >> 1] & 0x0F) | (color << 4);
        // Display this half of the image
        epd.EPD_5IN65F_Display_part(halfBuffer, 0, startY, EPD_WIDTH, HALF_HEIGHT);
        Serial.printf("Displayed half %d\n", half + 1);
    free(halfBuffer);
    free(lineBuffer);
    bmpFS.close();
    Serial.println("Image display complete");
    return true;
int depalette(uint8_t r, uint8_t g, uint8_t b) {
    int p;
    int mindiff = 100000000;
    int bestc = 0;
    for(p = 0; p < sizeof(colorPallete)/3; p++) {
        int diffr = ((int)r) - ((int)colorPallete[p*3+0]);
        int diffg = ((int)g) - ((int)colorPallete[p*3+1]);
        int diffb = ((int)b) - ((int)colorPallete[p*3+2]);
        int diff = (diffr*diffr) + (diffg*diffg) + (diffb * diffb);
        if(diff < mindiff) {
            mindiff = diff;
            bestc = p;
    return bestc;
void checkSDFiles() {
    Serial.println("Checking info.txt File");
    File infoFile = SD.open("/info.txt");
    if (!infoFile) {
        Serial.println("info.txt not found");
        return;
    String infoText = "";
    while (infoFile.available()) {
        infoText += (char)infoFile.read();
    infoFile.close();
    Serial.println("Content of info.txt: " + infoText);
    if(preferences.getString("checker", "") != infoText) {
        Serial.println("Check SD File");
        File root = SD.open("/");
        String fileString = "";
        std::vector<String> bmpFiles;
        while (true) {
            File entry = root.openNextFile();
            if (!entry) {
                root.close();
            uint8_t nameSize = String(entry.name()).length();
            String str1 = String(entry.name()).substring(nameSize - 4);
            if (str1.equalsIgnoreCase(".bmp")) {
                bmpFiles.push_back(entry.name());
                Serial.println(String(entry.name()));
            entry.close();
        std::sort(bmpFiles.begin(), bmpFiles.end());
        for (const String& file : bmpFiles) {
            fileString += file + ",";
        preferences.putUInt("fileCount", bmpFiles.size());
        preferences.putUInt("imageIndex", 0);
        preferences.putString("checker", infoText);
        File file = SD.open("/fileString.txt", FILE_WRITE);
        if(!file) {
            Serial.println("Failed to open file for writing");
            return;
        file.print(fileString);
        file.close();
String getNextFile() {
    File file = SD.open("/fileString.txt");
    if(!file) {
        Serial.println("Failed to open file for reading");
        return "";
    while(file.available()) {
        fileString += (char)file.read();
    file.close();
    String date;
    if(timeWorking) {
        if (timeinfo.tm_hour < 9) {
            time_t previousDay = mktime(&timeinfo) - 24 * 60 * 60;
            struct tm* previousDayInfo = localtime(&previousDay);
            date = String(previousDayInfo->tm_mday < 10 ? "0" : "") +
                   String(previousDayInfo->tm_mday) + "." +
                   String((previousDayInfo->tm_mon + 1) < 10 ? "0" : "") +
                   String(previousDayInfo->tm_mon + 1);
            date = String(timeinfo.tm_mday < 10 ? "0" : "") +
                   String(timeinfo.tm_mday) + "." +
                   String((timeinfo.tm_mon + 1) < 10 ? "0" : "") +
                   String(timeinfo.tm_mon + 1);
        date = preferences.getString("date", "01.01");
        int day = date.substring(0, 2).toInt();
        int month = date.substring(3, 5).toInt();
        struct tm timeinfoTemp = {0};
        timeinfoTemp.tm_year = 2000 - 1900;
        timeinfoTemp.tm_mon = month - 1;
        timeinfoTemp.tm_mday = day + 1;
        mktime(&timeinfoTemp);
        char newDate[6];
        snprintf(newDate, sizeof(newDate), "%02d.%02d", timeinfoTemp.tm_mday, timeinfoTemp.tm_mon + 1);
        date = String(newDate);
    Serial.println("Looking for date: " + date);
    preferences.putString("date", date);
    int start = 0;
    int end = fileString.indexOf(",", start);
    String nextFile = "";
    while (end != -1) {
        String currentFile = fileString.substring(start, end);
        if (currentFile.indexOf(date) != -1) {
            nextFile = currentFile;
        start = end + 1;
    if (nextFile != "") {
        Serial.println("Found matching file: " + nextFile);
        return "/" + nextFile;
    Serial.println("No matching file found, using index-based selection");
    unsigned int fileCount = preferences.getUInt("fileCount", 0);
    unsigned int imageIndex = preferences.getUInt("imageIndex", 0);
    if(imageIndex >= fileCount - 1) {
        imageIndex = 0;
        imageIndex++;
    preferences.putUInt("imageIndex", imageIndex);
    start = 0;
    for(unsigned int i = 0; i < imageIndex; i++) {
        start = end + 1;
    nextFile = fileString.substring(start, end);
    Serial.println("Selected file by index: " + nextFile);
Please dig out the relevant technical information and post it here.
The only relevent technical information to this project would be code related is what I think. I can share the original code that I referred to with a link to the GitHub account. This is meant for the 7.3inch display (ino file only):
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include "epd7in3f.h"
#include <vector>
Epd epd;
// Color pallete for dithering. These are specific to the 7in3f waveshare display.
	0, 0, 0,
	255, 255, 255,
	67, 138, 28,
	100, 64, 255,
	191, 0, 0,
	255, 243, 56,
	232, 126, 0,
  uint16_t result;
  return result;
  uint32_t result;
  return result;
  delta = millis();
  // Set the analog read resolution to 12 bits for the battery voltage
  // Turn on the transistor to power the external components
  delay(10);
  // Initialize the SD card
    hibernate();
  // Initialize Wifi and get the time
  initializeWifi();
  initializeTime();
  // Initialize the e-paper display
    Serial.println("eP init F");
    hibernate();
  }else{
    Serial.println("eP init no F");
  checkSDFiles(); //Check if the SD files have changed and update the preferences if needed
  String file = getNextFile(); // Get the next file to display
  drawBmp(file.c_str()); // Display the file
  digitalWrite(TRANSISTOR_PIN, LOW); // Turn off external components
  preferences.end();
    hibernate();
void hibernate() {
    Serial.println("start sleep");
// Function to check if the SD files have changed and update the preferences if needed
void checkSDFiles(){
  File infoFile = SD.open("/info.txt");  // Try to open info.txt
  if (!infoFile) {
    return;  // Exit if file not found
    infoText += (char)infoFile.read();  // Read file content into a String
  infoFile.close();  // Close the file after reading
  // Check if the info.txt content has changed, if so update the preferences
  if(preferences.getString("checker", "") != infoText){
    u_int16_t fileCount = 0;
    // Get every filename in the root directory and save the ones with '.bmp' extension in the bmpFiles vector
    while (true) {
      if (!entry) {
        Serial.println("No more files");
        // no more files
        root.close();
      uint8_t nameSize = String(entry.name()).length();  // get file name size
      String str1 = String(entry.name()).substring( nameSize - 4 );  // save the last 4 characters (file extension)
      if ( str1.equalsIgnoreCase(".bmp") ) {  // if the file has '.bmp' extension
        Serial.println(String(entry.name()));  // print the file name
      entry.close();  // close the file
    // Create a string with all the file names separated by commas
    for (int i = 0; i < bmpFiles.size(); i++) {
      fileString += bmpFiles[i] + ",";  // add file name to fileString
    // Reset preferences values
    // Save the fileString to a txt file to parse the files later
    if(!file){
      return;
    file.close();
// Function to get the next file to display
String getNextFile(){
  // Read fileString from txt file
  if(!file){
    return "";
  while(file.available()){
  file.close();
  String date;
  // If time is working, get the date from the timeinfo struct to display a image set for that day
  if(timeWorking){
    Serial.println("timeinfo.tm_hour: " + String(timeinfo.tm_hour));
    Serial.println("timeinfo.tm_min: " + String(timeinfo.tm_min));
      Serial.println("Getting the date of the previous day");
      // Get the date of the previous day
      date = String(previousDayInfo->tm_mday < 10 ? "0" : "") + String(previousDayInfo->tm_mday) + "." + String((previousDayInfo->tm_mon + 1) < 10 ? "0" : "") + String(previousDayInfo->tm_mon + 1);
      date = String(timeinfo.tm_mday < 10 ? "0" : "") + String(timeinfo.tm_mday) + "." + String((timeinfo.tm_mon + 1) < 10 ? "0" : "") + String(timeinfo.tm_mon + 1);
  // If time is not working, get the date from the preferences to display the next image in the list. The date is updated every time the device obtains the time.
  }else{
    //Added for leap year (Years don't matter for this project, years are not checked)
    int year = 2000;
    timeinfoTemp.tm_year = year - 1900;
    timeinfoTemp.tm_mon = month - 1; // tm_mon is 0-based
    timeinfoTemp.tm_mday = day;
    // Add one day
    timeinfoTemp.tm_mday += 1;
    // Normalize the time structure (this will handle month/year overflow)
    // Format the new date back to a string
    char newDate[6];
    // Save the new date
    Serial.println("New date: " + date);
  Serial.println("date: " + date);
  int start = 0;
  // Get the next file from the fileString based on the date
  while (true) {
    Serial.println("currentFile: " + currentFile);
    Serial.println("currentFile.indexOf(date): " + currentFile.indexOf(date));
    start = end + 1;
    if (end == -1) {
  // If no file was found for the date, get the next file in the list based on the imageIndex
  unsigned int temp = imageIndex;
  if(imageIndex >= fileCount - 1){
    imageIndex = 0;
  }else{
    imageIndex++;
  start = 0;
  for(int i = 0; i < temp; i++){
    start = end + 1;
  Serial.println("nextFile: " + nextFile);
// Function to draw a BMP image on the e-paper display
  fs::File bmpFS;
  bmpFS =  SD.open(filename); // Open requested file on SD card
  uint32_t seekOffset, headerSize, paletteSize = 0;
  int16_t row;
  uint8_t r, g, b;
  uint16_t bitDepth;
  if (magic != ('B' | ('M' << 8))) { // File not found or not a BMP
    Serial.println(F("BMP not found!"));
    bmpFS.close();
    return false;
  read32(bmpFS); // filesize in bytes
  seekOffset = read32(bmpFS); // start of bitmap
  headerSize = read32(bmpFS); // header size
  uint32_t w = read32(bmpFS); // width
  uint32_t h = read32(bmpFS); // height
  read16(bmpFS); // color planes (must be 1)
  // Check if the BMP is valid
  if (read32(bmpFS) != 0 || (bitDepth != 24 && bitDepth != 1 && bitDepth != 4 && bitDepth != 8)) {
    Serial.println(F("BMP format not recognized."));
    bmpFS.close();
    return false;
  if (bitDepth <= 8) // 1,4,8 bit bitmap: read color palette
    read32(bmpFS); read32(bmpFS); read32(bmpFS); // size, w resolution, h resolution
    if (paletteSize == 0) paletteSize = bitDepth * bitDepth; //if 0, size is 2^bitDepth
    bmpFS.seek(14 + headerSize); // start of color palette
  // draw img that is shorter than display in the middle
  uint16_t x = (width() - w) /2;
  uint16_t y = (height() - h) /2;
  bmpFS.seek(seekOffset);
  uint32_t lineSize = ((bitDepth * w +31) >> 5) * 4;
  uint8_t lineBuffer[lineSize];
  uint8_t nextLineBuffer[lineSize];
  epd.SendCommand(0x10); // start data frame
  epd.EPD_7IN3F_Draw_Blank(y, width(), EPD_7IN3F_WHITE); // fill area on top of pic white
  // row is decremented as the BMP image is drawn bottom up
  bmpFS.read(lineBuffer, sizeof(lineBuffer));
  //reverse linBuffer with the alorithm library
  std::reverse(lineBuffer, lineBuffer + sizeof(lineBuffer));
  int batteryVolts = analogReadMilliVolts(0);
  batteryVolts = batteryVolts * 1.69657;
  for (row = h-1; row >= 0; row--) {
    epd.EPD_7IN3F_Draw_Blank(1, x, EPD_7IN3F_WHITE); // fill area on the left of pic white
    if(row != 0){
      bmpFS.read(nextLineBuffer, sizeof(nextLineBuffer));
      std::reverse(nextLineBuffer, nextLineBuffer + sizeof(nextLineBuffer));
    uint8_t*  bptr = lineBuffer;
    uint8_t*  bnptr = nextLineBuffer;
    uint8_t output = 0;
    for (uint16_t col = 0; col < w; col++)
      // Get r g b values for the next pixel
        r = *bptr++;
        g = *bptr++;
        b = *bptr++;
        bnptr += 3;
        uint32_t c = 0;
          c = palette[*bptr++];
          c = palette[(*bptr >> ((col & 0x01)?0:4)) & 0x0F];
          if (col & 0x01) bptr++;
          c = palette[(*bptr >> (7 - (col & 0x07))) & 0x01];
          if ((col & 0x07) == 0x07) bptr++;
        b = c; g = c >> 8; r = c >> 16;
      // Floyd-Steinberg dithering is used to dither the image
      uint8_t color;
      int indexColor;
      int errorR;
      int errorG;
      int errorB;
      indexColor = depalette(r, g, b); // Get the index of the color in the colorPallete
      errorR = r - colorPallete[indexColor*3+0];
      errorG = g - colorPallete[indexColor*3+1];
      errorB = b - colorPallete[indexColor*3+2];
      if(col < w-1){
        bptr[0] = constrain(bptr[0] + (7*errorR/16), 0, 255);
        bptr[1] = constrain(bptr[1] + (7*errorG/16), 0, 255);
        bptr[2] = constrain(bptr[2] + (7*errorB/16), 0, 255);
      if(row > 0){
        if(col > 0){
          bnptr[-4] = constrain(bnptr[-4] + (3*errorR/16), 0, 255);
          bnptr[-5] = constrain(bnptr[-5] + (3*errorG/16), 0, 255);
          bnptr[-6] = constrain(bnptr[-6] + (3*errorB/16), 0, 255);
        bnptr[-1] = constrain(bnptr[-1] + (5*errorR/16), 0, 255);
        bnptr[-2] = constrain(bnptr[-2] + (5*errorG/16), 0, 255);
        bnptr[-3] = constrain(bnptr[-3] + (5*errorB/16), 0, 255);
        if(col < w-1){
          bnptr[0] = constrain(bnptr[0] + (1*errorR/16), 0, 255);
          bnptr[1] = constrain(bnptr[1] + (1*errorG/16), 0, 255);
          bnptr[2] = constrain(bnptr[2] + (1*errorB/16), 0, 255);
      // Set the color based on the indexColor
      switch (indexColor){
        case 0:
          color = EPD_7IN3F_BLACK;
        case 1:
          color = EPD_7IN3F_WHITE;
        case 2:
          color = EPD_7IN3F_GREEN;
        case 3:
          color = EPD_7IN3F_BLUE;
        case 4:
          color = EPD_7IN3F_RED;
        case 5:
          color = EPD_7IN3F_YELLOW;
        case 6:
          color = EPD_7IN3F_ORANGE;
        case 7:
      // Set the color in the bottom right based on the battery voltage
      if (batteryVolts <= 3500 && batteryVolts >=1000 && col <= 50 && row >= h-50){
      // Vodoo magic i don't understand
      uint32_t buf_location = (row*(width()/2)+col/2);
      if (col & 0x01) {
        output |= color;
        epd.SendData(output);
        output = color << 4;
    epd.EPD_7IN3F_Draw_Blank(1, x, EPD_7IN3F_WHITE); // fill area on the right of pic white
    memcpy(lineBuffer, nextLineBuffer, sizeof(lineBuffer));
  epd.EPD_7IN3F_Draw_Blank(y, width(), EPD_7IN3F_WHITE); // fill area below the pic white
  bmpFS.close(); // Close the file
  epd.TurnOnDisplay(); // Turn on the display
  return true;
// Function to depalette the image
int depalette( uint8_t r, uint8_t g, uint8_t b ){
	int p;
	int bestc = 0;
  // Find the color in the colorPallete that is closest to the r g b values
	for( p = 0; p < sizeof(colorPallete)/3; p++ )
		if( diff < mindiff )
			mindiff = diff;
			bestc = p;
	return bestc;
This code would be suitable for the 7.3 inch 7color epd from waveshare. I doesn't work with my 5.65 inch model. That's why I showed in my first post the version I tried to make of it, but I always seem to run out of buffer (in the esp32) so I have the image in 2, which does not seems to work with this type of display or i'm doing something wrong. Anyways, I want to and should be able to create the image in 1 go with an esp32, so my question is: what is the step I need to take to get that setup
Hmm... does this explain what you are seeing?
This is for the example code (the project I referred to). The code that I wrote (see first post) shows my adaptation for the 5.65 inch display
Do the width and height functions return the correct values?
Would that matter? The values return 800 by 640 if I recall correctly. The screen draws the images as you can see, but only on halves. The issue seems to be memory related
