E.L. Heart Rate Montitor Interference problem
I have made a suit covered in EL wire that responds to the wearers heartbeat for a dance performance. Independantly, the circuit switching the EL wire and the circuit with the heart rate monitor work fine. However when the heart rate monitor is too close to the EL wire it gets interference and cant produce a regular signal. I know El is known for creating electrical noise, so i was wondering if there is any known way around this problem.
I am using an optocoupler and triac to switch the EL wire. The inverter powering it output 110v ac at 1800Hz.
The Heart rate monitor is is a Polar T31 chest belt and Polar receiver RMCM01 this transmits low frequency EMF.
http://www.sparkfun.com/commerce/product_info.php?products_id=8660
There are a couple of approaches i am considering to try and get around the interference problem:
  1. try using a different heart monitor. Garmin produce a chest belt monitor that works with this receiver http://www.sparkfun.com/commerce/product_info.php?products_id=8565 one that works at 2.4GHz the problem with this plan is that it costs a bit so i didn’t want to try it on the off chance it will work.
  2. making my own Heart monitor using two stick on electrodes http://pulsemedical.co.uk/product_info.php?cPath=50&products_id=137&osCsid=b81f213296a3437ecabf3beff441e783
    and amplifying the signal. I was going to try using this preamp http://www.maplin.co.uk/module.aspx?moduleno=37746
    I was planning on running it into an analogue pin on the arduino and setting it to read as ‘high’ when the voltage crosses a certain threshold (though im not sure how to do this yet). As far as getting around the interference problem with this design i am going to use screened cable and put the amplifier in a metal box.
Any Ideas Folks? Any input is much appreciated.
I tried a test of the heart monitor circuit (without the El circuit) but without any luck yet. i connected two 'postive' electrodes to me and the other end of the wires together and then into the pre amp 'in' i connected a third GND electrode to myself and ran this as gnd to a volt meter. the output of the pre amp i ran to the positive of the voltmeter. i powered the preamp with 12v dc from a bench top supply. I did not get any reading from the voltmeter it just fluctuated at random.
I checked the pre amp circuit worked by amplifying an audio signal from an mp3 player. it amplified the sinal and gave a clear voltage reading, even if the sound was a little 'noisy'.
...also i just re-read the preamp info sheet and it said input frequency range is 10-100Hz. Maybe i need to be using a more specific amplification circuit to make this work...back to the drawing board!
i came across this http://www.analog.com/library/analogDialogue/archives/29-3/voltage.html the section for pulse monitor has a specific amplifier circuit for this, so i'll give it a go and report back...
