E-Paper Display trouble sending serial string
Hi Guys,
I'm currently working on a project to display a String on the e-Paper display by waveshare.
I've set up everything and modified the demo program, that is shipped by waveshare.
I can display any text i create in that file.
However I'm trying to receive text via Serial.read() that is sent by the Arduino software. (e.G. "Hello").
To start off, my code looks like this:
* File                : Arduino-epd
* Hardware Environment:
* Build Environment   : Arduino
* Version             : V1.6.1
* By                  : WaveShare
*                                  (c) Copyright 2005-2015, WaveShare
*                                       http://www.waveshare.net
*                                       http://www.waveshare.com
*                                          All Rights Reserved
#include "epd.h"
const int led = 13;                           //user led
char tmp = -1;
void draw_text_demo(const void *str)
  epd_set_color(BLACK, WHITE);
  epd_clear();
  char* ptr = (char*)str;
  epd_set_en_font(ASCII64);
  epd_disp_string(ptr, 200, 250);
  Serial.print(ptr);
  epd_udpate();
  delay(3000);
void setup(void)
  user led init
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
  epd_init();
  epd_wakeup();
  epd_set_memory(MEM_NAND);
   start serial connection
void loop(void)
  Draw text demo
  char str[5];
   Wait for serial input
  if (Serial.available() > 0){
    int index = 0;
    while (Serial.available() > 0)
      tmp = Serial.read();
      str[index] = tmp;
      index++;
    str[index] = '\0';
    draw_text_demo(str);
The corresponding cpp method epd_disp_string() looks like this:
* Function Name  : void epd_disp_string(const void * p, int x0, int y0)
* Description    :
* Input          :
* Output         : None
* Return         :
* Attention		   : None
	int string_size;
	unsigned char * ptr = (unsigned char *)p;
	string_size = strlen((const char *)ptr);
	string_size += 14;
	_cmd_buff[0] = FRAME_B;
	_cmd_buff[1] = (string_size >> 8) & 0xFF;
	_cmd_buff[2] = string_size & 0xFF;
	_cmd_buff[3] = CMD_DRAW_STRING;
	_cmd_buff[4] = (x0 >> 8) & 0xFF;
	_cmd_buff[5] = x0 & 0xFF;
	_cmd_buff[6] = (y0 >> 8) & 0xFF;
	_cmd_buff[7] = y0 & 0xFF;
	strcpy((char *)(&_cmd_buff[8]), (const char *)ptr);
	string_size -= 5;
	_cmd_buff[string_size] = FRAME_E0;
	_cmd_buff[string_size + 1] = FRAME_E1;
	_cmd_buff[string_size + 2] = FRAME_E2;
	_cmd_buff[string_size + 3] = FRAME_E3;
	_cmd_buff[string_size + 4] = _verify(_cmd_buff, string_size + 4);
	_putchars(_cmd_buff, string_size + 5);
Everything compiles without any exception or warning.
BUT: When I run the program and try to send a String, the display does not react, but however the correct String is sent back to the Serial Monitor on my PC (via Serial.print(ptr) inside draw_text_demo()). So the the Arduino receives the String correctly, it just seems like it is unable to run the .cpp method epd_disp_string() as seen above.
When I overwrite the str variable inside the code to single chars like:
      str[0] = (char)'H';
      str[1] = (char)'E';
      str[2] = (char)'L';
      str[3] = (char)'L';
      str[4] = (char)'O';
      str[5] = '\0';
and pass it to draw_text_demo() everything works perfectly fine. The screen displays the string and the string is sent back to the Serial Monitor.
Am I missing something with Serial.read()? I feel like the values inside the char-array 'str' are not real chars. Is that possible?
It's a long time since I've been programming in C++ the last time, but I don't think its a syntax issue. Or is it?
Hopefully i didn't miss any important information. If so, feel free to ask.
Thank you so much in advance guys, I'm really stuck in this one. :confused:
Best wishes
Tobi
Hi Tobi
From the code snippet of your code it is hard to tell what is wrong. You might show more of your code.
Maybe you confound C “string” character arrays with C++ String class?
The Waveshare demo code is not so nice to use; I converted it to a C++ class. See attached zip.
Jean-Marc
WVS43EPD.zip (5.02 KB)
