Hi all,
I am currently having issues with uploading my code to my Arduino. Currently, i am using a lilypad temperature sensor and a lilypad main board sewed together (see image) This is then connected to an Arduino Uno and then my laptop.
But there is an error in the programmer (see comments), I have changed all the ports, board, processor and programmer but there has been no change still the error comes up. Can anyone please help
gracec2431:
But there is an error in the programmer (see image),
Please don't post pictures of text. That is very unhelpful. When you encounter an error you'll see a button on the right side of the orange bar in the Arduino IDE "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button. In a message here, click the code tags button (</> on the forum toolbar) and then paste the error.
If the text exceeds the forum's 9000 character limit, save it to a .txt file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link.
Arduino: 1.8.12 (Mac OS X), Board: "LilyPad Arduino, ATmega168"
Sketch uses 1642 bytes (11%) of program storage space. Maximum is 14336 bytes.
Global variables use 190 bytes (18%) of dynamic memory, leaving 834 bytes for local variables. Maximum is 1024 bytes.
/Users/gracecooper/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/gracecooper/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega168 -carduino -P/dev/cu.usbmodem14301 -b19200 -D -Uflash:w:/var/folders/gj/syj9s8d51xzflb0tt7b5m5h40000gn/T/arduino_build_304355/draft1.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/gracecooper/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/gracecooper/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14301
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
gracec2431:
Unplug and plug your board back in.
Restart the Arduino IDE.
Disconnect all wires and try uploading a simple blink sketch.
Make sure you have nothing connected to pins 0 and 1 while uploading a sketch.
If you still have trouble, try reinstalling the Arduino IDE. Or check your USB port and cable connection. If the problem persists, you may have overvolted your board like I did :/.
Good Luck!
