E-Vent.MIT help finding replacement parts
Dear arduino community,
In response to emergency MIT have been working on their own ventilator.
All their data are available on their site, link at the end of text.
Main problem is that two main elements are not for sale anymore.
  1. Motor with encoder (PG Series Gearboxes Gear ratio 188/1, insatalled encoder, shaft 3/8 Hex)
  2. motor controller. (RoboClaw Solo motor controller)
How simple we can make 30A H bridge PWM contorler?
Please share some links.
What motor we can use to meet desired specifications especiialy 2 week duty cycle of 100% and 1 milion cycles.
Motor specification:
PG188 Specifications:
Gearbox Reduction: 188:1
No Load Free Speed: 28 RPM
Stall Torque: 33 ft-lbf = 44.74Nm
Minimum Backdrive Torque: 3.5 ft-lbs
Radial load: 690 N
Torque: 15 N-m
Quadrature encoder integrated (ours provides 7 pulses / rev of motor shaft)
Motor controller specifications:
Roboclaw Solo 30A, 34VDC Motor Controller
Features:
30 Amps Continuous
45 Amps Peak
Encoders Supported
Position Control
Auto PID Tunning
Multimode Control Interface
USB, Serial, R/C, Analog Inputs
Limit, Home and E-Stops
Up to 34VDC Operation
Listo of neded materials.
Power supply 12VDC 5A
Arduino UNO
Pressure sensor - diferential
POT1 - Inspired Volume, single turn 10KΩ
POT2 - BPM breaths per minute, single turn 10KΩ
POT3 - I:E ratio, single turn 10KΩ
POT4 - pressure threshold for detecting assist control, single turn 10KΩ
Switch - Power on /off
E-stop
Toggle Switch – Mode selection from volume to assist control.
Momentary Button 1 – Used to temporarily silence alarms. This must be debounced.
Momentary Button 1 – Used to confirm a change to one of the POTs. This is a necessary safety feature. This must be debounced.
Limit Switch – Used for homing the arms positions.
LCD 20x4 or LCD 20x2
Audible alert buzzer will identify multiple fault conditions.
Red LED
Green Led
220 Ohm resistor
220 Ohm resistor
Laser Cut Aluminum Sheets - 1/4"(6.35mm)
AmbuBag
Breathing Tubes
Project main site:
Schematics for laser cutter or CNC:
MIT-E-Vent-Pre-Production-Model.zip (1.41 MB)
All disclaimers apply but a quick search gave a couple of motor driver possibilities
https://www.aliexpress.com/item/32276518384.html?spm=a2g0o.detail.1000023.20.3aaa61bbCHOG7f
https://www.aliexpress.com/item/32728776675.html
I have always controlled motors using 75N75, that's the best FET, can hold up to 8A current.
