Eachine E010 control with Arduino
For a project I must control an Eachine E010 drone with an arduino. I have found this github repo doing something similar as what I want to do but the code is a little on the complicated side for me. The first step is controlling the drone.
I would like to know how I would go about reverse engineering the transmitter for the drone so I can 'copy' the controls and control the drone with an Arduino. And yes I have an NRF24L01 at home.
When doing research I stumbled across a few forums not related to Arduino that talk about the transmitter protocol and how a professional drone controller can be connected with the E010. I thought about simply receiving all the transmitter data, but for example, how would one go about selecting the right channel... and the right payload size etc.
Appreciate the help.
D.
I'd start with these two files.
The first one gets the control positions from a RC transmitter.
The second one sends the control positions to the E010 quadcopter.
What do you mean by having the Arduino "fly" the quadcopter? It can send control signals but has no way of knowing where the quadcopter is or which way it is heading. The project you pointed to uses a PC with a camera and Open Computer Vision software to watch the quadcopter.
Ok, I'll take another look at those files again.
At first I was a bit overwhelmed by the code in those files because it looks like they wrote their own nrf24 software instead of using a library.
johnwasser:
I ment controlling it. I have my own plans for determining the position.
Thanks
@johnwasser I have now extensively studied both files and some others in the same repo. I am still totally baffled by both of them as to what they do and how. What should I do next? How will I be able to control the E010 quadcopter with my nano?
I'd start by copying the nRF24_multipro.ino into a new sketch. Add tabs for MJX.ino nRF24L01.ino, softSPI.ino and iface_nref24l01.h.
You will find several big 'switch' statements that reference all of the protocols. Remove every part of the statement that is not inside the PROTO_E010 case.
Comment out 'frskyInit()' from setup() and 'frskyUpdate()' from loop(). Those have something to do with reading values from the manual controls on an RC transmitter. Similarly, remove the ISR_ppm() and update_ppm() functions. Where the update_ppm() is called would be the place where your Arduino decides what values to set for each of the 12 control channels.
This is my current file with the changes made you told me to make: (Had to post in two replies because exceeds 9000 characters, rest will follow in 5 minutes)
It compiles but I still have some questions.
#include <util/atomic.h>
#include <EEPROM.h>
#include "iface_nrf24l01.h"
// ############ Wiring ################
#define PPM_pin   2  // PPM in
//SPI Comm.pins with nRF24L01
#define MOSI_pin  3  // MOSI - D3
#define SCK_pin   4  // SCK  - D4
#define CE_pin    5  // CE   - D5
#define MISO_pin  A0 // MISO - A0
#define CS_pin    A1 // CS   - A1
#define ledPin    13 // LED  - D13
// SPI outputs
#define MOSI_on PORTD |= _BV(3)  // PD3
#define MOSI_off PORTD &= ~_BV(3)// PD3
#define SCK_on PORTD |= _BV(4)   // PD4
#define SCK_off PORTD &= ~_BV(4) // PD4
#define CE_on PORTD |= _BV(5)    // PD5
#define CE_off PORTD &= ~_BV(5)  // PD5
#define CS_on PORTC |= _BV(1)    // PC1
#define CS_off PORTC &= ~_BV(1)  // PC1
// SPI input
#define  MISO_on (PINC & _BV(0)) // PC0
#define RF_POWER TX_POWER_80mW
// tune ppm input for "special" transmitters
// #define SPEKTRUM // TAER, 1100-1900, AIL & RUD reversed
// PPM stream settings
#define CHANNELS 12 // number of channels in ppm stream, 12 ideally
enum chan_order{
    THROTTLE,
    AILERON,
    ELEVATOR,
    RUDDER,
    AUX1,  // (CH5)  led light, or 3 pos. rate on CX-10, H7, or inverted flight on H101
    AUX2,  // (CH6)  flip control
    AUX3,  // (CH7)  still camera (snapshot)
    AUX4,  // (CH8)  video camera
    AUX5,  // (CH9)  headless
    AUX6,  // (CH10) calibrate Y (V2x2), pitch trim (H7), RTH (Bayang, H20), 360deg flip mode (H8-3D, H22)
    AUX7,  // (CH11) calibrate X (V2x2), roll trim (H7), emergency stop (Bayang, Silverware)
    AUX8,  // (CH12) Reset / Rebind
#define PPM_MIN 1000
#define PPM_SAFE_THROTTLE 1050
#define PPM_MID 1500
#define PPM_MAX 2000
#define PPM_MIN_COMMAND 1300
#define PPM_MAX_COMMAND 1700
#define GET_FLAG(ch, mask) (ppm[ch] > PPM_MAX_COMMAND ? mask : 0)
#define GET_FLAG_INV(ch, mask) (ppm[ch] < PPM_MIN_COMMAND ? mask : 0)
// supported protocols
enum {
    PROTO_V2X2 = 0,     // WLToys V2x2, JXD JD38x, JD39x, JJRC H6C, Yizhan Tarantula X6 ...
    PROTO_CG023,        // EAchine CG023, CG032, 3D X4
    PROTO_CX10_BLUE,    // Cheerson CX-10 blue board, newer red board, CX-10A, CX-10C, Floureon FX-10, CX-Stars (todo: add DM007 variant)
    PROTO_CX10_GREEN,   // Cheerson CX-10 green board
    PROTO_H7,           // EAchine H7, MoonTop M99xx
    PROTO_BAYANG,       // EAchine H8(C) mini, H10, BayangToys X6, X7, X9, JJRC JJ850, Floureon H101
    PROTO_SYMAX5C1,     // Syma X5C-1 (not older X5C), X11, X11C, X12
    PROTO_YD829,        // YD-829, YD-829C, YD-822 ...
    PROTO_H8_3D,        // EAchine H8 mini 3D, JJRC H20, H22
    PROTO_MJX,          // MJX X600 (can be changed to Weilihua WLH08, X800 or H26D)
    PROTO_SYMAXOLD,     // Syma X5C, X2
    PROTO_HISKY,        // HiSky RXs, HFP80, HCP80/100, FBL70/80/90/100, FF120, HMX120, WLToys v933/944/955 ...
    PROTO_KN,           // KN (WLToys variant) V930/931/939/966/977/988
    PROTO_YD717,        // Cheerson CX-10 red (older version)/CX11/CX205/CX30, JXD389/390/391/393, SH6057/6043/6044/6046/6047, FY326Q7, WLToys v252 Pro/v343, XinXun X28/X30/X33/X39/X40
    PROTO_FQ777124,     // FQ777-124 pocket drone
    PROTO_E010,         // EAchine E010, NiHui NH-010, JJRC H36 mini
    PROTO_BAYANG_SILVERWARE, // Bayang for Silverware with frsky telemetry
    PROTO_END
// EEPROM locationss
enum{
    ee_PROTOCOL_ID = 0,
    ee_TXID0,
    ee_TXID1,
    ee_TXID2,
    ee_TXID3
struct {
    uint16_t volt1;
    uint16_t rssi;
    uint8_t updated;
    uint32_t lastUpdate;
} telemetry_data;
uint8_t transmitterID[4];
uint8_t current_protocol;
static volatile bool ppm_ok = false;
uint8_t packet[32];
static bool reset=true;
volatile uint16_t Servo_data[12];
static uint16_t ppm[12] = {PPM_MIN,PPM_MIN,PPM_MIN,PPM_MIN,PPM_MID,PPM_MID,
                           PPM_MID,PPM_MID,PPM_MID,PPM_MID,PPM_MID,PPM_MID,};
    randomSeed((analogRead(A4) & 0x1F) | (analogRead(A5) << 5));
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, LOW); //start LED off
    pinMode(PPM_pin, INPUT);
    pinMode(MOSI_pin, OUTPUT);
    pinMode(SCK_pin, OUTPUT);
    pinMode(CS_pin, OUTPUT);
    pinMode(CE_pin, OUTPUT);
    pinMode(MISO_pin, INPUT);
//    frskyInit();
    // PPM ISR setup
    // Removed
    //attachInterrupt(digitalPinToInterrupt(PPM_pin), ISR_ppm, CHANGE);
    TCCR1A = 0;  //reset timer1
    TCCR1B = 0;
    TCCR1B |= (1 << CS11);  //set timer1 to increment every 1 us @ 8MHz, 0.5 us @16MHz
    // Removed becaues not declared in scope
    //set_txid(false);
You said
johnwasser:
How would you set these values to in place of update_ppm() void? I don’t see how this has to be done. Also, the SPI pins in the program do not seem to match the SPI pins on my nano. E.G MOSI = D3 but on the nano it is D11. Should I change these to match the SPI pin configuration on my nano?
I really appreciate it you helping me.
    uint32_t timeout=0;
    // reset / rebind
    if(reset || ppm[AUX8] > PPM_MAX_COMMAND) {
        reset = false;
        selectProtocol();
        NRF24L01_Reset();
        NRF24L01_Initialize();
        init_protocol();
    telemetry_data.updated = 0;
    // process protocol
    // Removed big switch statement
    timeout = process_MJX();
    // updates ppm values out of ISR
    // Removed
    //update_ppm();
//    while(micros() < timeout) {
//        if(telemetry_data.updated) {
//            frskyUpdate();
void set_txid(bool renew)
    uint8_t i;
    for(i=0; i<4; i++)
        transmitterID[i] = EEPROM.read(ee_TXID0+i);
    if(renew || (transmitterID[0]==0xFF && transmitterID[1]==0x0FF)) {
        for(i=0; i<4; i++) {
            transmitterID[i] = random() & 0xFF;
            EEPROM.update(ee_TXID0+i, transmitterID[i]);
void selectProtocol()
    // wait for multiple complete ppm frames
    ppm_ok = false;
    uint8_t count = 10;
    while(count) {
        while(!ppm_ok) {} // wait
        // Removed
        //update_ppm();
        if(ppm[AUX8] < PPM_MAX_COMMAND) // reset chan released
            count--;
        ppm_ok = false;
    // startup stick commands (protocol selection / renew transmitter ID)
    if(ppm[RUDDER] < PPM_MIN_COMMAND && ppm[AILERON] < PPM_MIN_COMMAND) // rudder left + aileron left
        current_protocol = PROTO_BAYANG_SILVERWARE; // Bayang protocol for Silverware with frsky telemetry
    else if(ppm[RUDDER] < PPM_MIN_COMMAND)   // Rudder left
        set_txid(true);                      // Renew Transmitter ID
    // Rudder right + Aileron right + Elevator down
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[AILERON] > PPM_MAX_COMMAND && ppm[ELEVATOR] < PPM_MIN_COMMAND)
        current_protocol = PROTO_E010; // EAchine E010, NiHui NH-010, JJRC H36 mini
    // Rudder right + Aileron right + Elevator up
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[AILERON] > PPM_MAX_COMMAND && ppm[ELEVATOR] > PPM_MAX_COMMAND)
        current_protocol = PROTO_FQ777124; // FQ-777-124
    // Rudder right + Aileron left + Elevator up
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[AILERON] < PPM_MIN_COMMAND && ppm[ELEVATOR] > PPM_MAX_COMMAND)
        current_protocol = PROTO_YD717; // Cheerson CX-10 red (older version)/CX11/CX205/CX30, JXD389/390/391/393, SH6057/6043/6044/6046/6047, FY326Q7, WLToys v252 Pro/v343, XinXun X28/X30/X33/X39/X40
    // Rudder right + Aileron left + Elevator down
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[AILERON] < PPM_MIN_COMMAND && ppm[ELEVATOR] < PPM_MIN_COMMAND)
        current_protocol = PROTO_KN; // KN (WLToys variant) V930/931/939/966/977/988
    // Rudder right + Elevator down
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[ELEVATOR] < PPM_MIN_COMMAND)
        current_protocol = PROTO_HISKY; // HiSky RXs, HFP80, HCP80/100, FBL70/80/90/100, FF120, HMX120, WLToys v933/944/955 ...
    // Rudder right + Elevator up
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[ELEVATOR] > PPM_MAX_COMMAND)
        current_protocol = PROTO_SYMAXOLD; // Syma X5C, X2 ...
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[AILERON] > PPM_MAX_COMMAND)
        current_protocol = PROTO_MJX; // MJX X600, other sub protocols can be set in code
    else if(ppm[RUDDER] > PPM_MAX_COMMAND && ppm[AILERON] < PPM_MIN_COMMAND)
        current_protocol = PROTO_H8_3D; // H8 mini 3D, H20 ...
    // Elevator down + Aileron right
    else if(ppm[ELEVATOR] < PPM_MIN_COMMAND && ppm[AILERON] > PPM_MAX_COMMAND)
        current_protocol = PROTO_YD829; // YD-829, YD-829C, YD-822 ...
    // Elevator down + Aileron left
    else if(ppm[ELEVATOR] < PPM_MIN_COMMAND && ppm[AILERON] < PPM_MIN_COMMAND)
        current_protocol = PROTO_SYMAX5C1; // Syma X5C-1, X11, X11C, X12
    // Elevator up + Aileron right
    else if(ppm[ELEVATOR] > PPM_MAX_COMMAND && ppm[AILERON] > PPM_MAX_COMMAND)
        current_protocol = PROTO_BAYANG;    // EAchine H8(C) mini, BayangToys X6/X7/X9, JJRC JJ850 ...
    // Elevator up + Aileron left
    else if(ppm[ELEVATOR] > PPM_MAX_COMMAND && ppm[AILERON] < PPM_MIN_COMMAND)
        current_protocol = PROTO_H7;        // EAchine H7, MT99xx
    // Elevator up
    else if(ppm[ELEVATOR] > PPM_MAX_COMMAND)
        current_protocol = PROTO_V2X2;       // WLToys V202/252/272, JXD 385/388, JJRC H6C ...
    // Elevator down
    else if(ppm[ELEVATOR] < PPM_MIN_COMMAND)
        current_protocol = PROTO_CG023;      // EAchine CG023/CG031/3D X4, (todo :ATTOP YD-836/YD-836C) ...
    // Aileron right
    else if(ppm[AILERON] > PPM_MAX_COMMAND)
        current_protocol = PROTO_CX10_BLUE;  // Cheerson CX10(blue pcb, newer red pcb)/CX10-A/CX11/CX12 ...
    // Aileron left
    else if(ppm[AILERON] < PPM_MIN_COMMAND)
        current_protocol = PROTO_CX10_GREEN;  // Cheerson CX10(green pcb)...
    // read last used protocol from eeprom
        current_protocol = constrain(EEPROM.read(ee_PROTOCOL_ID),0,PROTO_END-1);
    // update eeprom
    EEPROM.update(ee_PROTOCOL_ID, current_protocol);
    // wait for safe throttle
    while(ppm[THROTTLE] > PPM_SAFE_THROTTLE) {
        delay(100);
        // Removed
        //update_ppm();
void init_protocol()
  MJX_init();
  MJX_bind();
// update ppm values out of ISR
//void update_ppm()
//    for(uint8_t ch=0; ch<CHANNELS; ch++) {
//        ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
//            ppm[ch] = Servo_data[ch];
//#ifdef SPEKTRUM
//        if(ch == AILERON || ch == RUDDER) {
//            ppm[ch] = 3000-ppm[ch];
//        ppm[ch] = constrain(map(ppm[ch],1120,1880,PPM_MIN,PPM_MAX),PPM_MIN,PPM_MAX);
//#endif
//void ISR_ppm()
//    #if F_CPU == 16000000
//        #define PPM_SCALE 1L
//    #elif F_CPU == 8000000
//        #define PPM_SCALE 0L
//    #else
//        #error // 8 or 16MHz only !
//    #endif
//    static unsigned int pulse;
//    static unsigned long counterPPM;
//    static byte chan;
//    counterPPM = TCNT1;
//    TCNT1 = 0;
//    ppm_ok=false;
//    if(counterPPM < 510 << PPM_SCALE) {  //must be a pulse if less than 510us
//        pulse = counterPPM;
//    else if(counterPPM > 1910 << PPM_SCALE) {  //sync pulses over 1910us
//        chan = 0;
//    else{  //servo values between 510us and 2420us will end up here
//        if(chan < CHANNELS) {
//            Servo_data[chan]= constrain((counterPPM + pulse) >> PPM_SCALE, PPM_MIN, PPM_MAX);
//            if(chan==3)
//                ppm_ok = true; // 4 first channels Ok
//        chan++;
Duinogud:
How would you set these values to in place of update_ppm() void? I don't see how this has to be done.
  ppm[THROTTLE] = value in microseconds between 1000 and 2000
  ppm[AILERON]  = value in microseconds between 1000 and 2000
  ppm[ELEVATOR] = value in microseconds between 1000 and 2000
  ppm[RUDDER]   = value in microseconds between 1000 and 2000
Duinogud:
Since there is a file named 'softSPI.ino" in the build, I'd expect that to not be a problem.
