Eagle CAD + Clearance Errors understanding?
I am working my way through a few PCB 'attempts' and trying to learn Eagle along the way...
When I click on my errors icon.. I see a few dimension & clearance errors..etc
the clearance errors are usually a trace to close to a via or something...
I 'thought' I could just grab the trace and move/drag it a little bit more out of the way..or re-draw (which I havent learned to do fully yet)....
however when i do manage to edit the error enough. and I re-check the error icon... the same error is still there.. even though I 'fixed' it.. (apparently its not fixing it though)..
is there something that needs to be done? ( have tried re-saving and then re-checking the errors..etc.. (still there)
here is 1 example of a clearance error I cant get rid of..
any tips and tricks for re-editing/altering traces if they are a bit close or cause an error?
**I originally though I could just use the 'WIRE' tool and re-draw (either on top or bottom layer) or branch off to make a new/better route for the trace.. and go back and delete the other/old portion for the original trace..but i always get an error saying something about back annotation..etc.. (but I dont want to remove the whole trace/net.. just that portion where I have re-drawn it)
anyways.. Im stumped on how to clear these clearance errors!??
thanks! :)
Not having Eagle on my work computer, I can't remember exactly, but I think there is a button "Processed" that you can hit and it should take that error away. You can then run it again to still see if there is an error.
I tried that.. but it only greys out the 'error' line.. and if I hit error icon again in PCB editor.. the are still there (grey'd out)??
xl97:
Are you running the design check again by hitting the Design Rule Check button, or are you just clicking the show errors button that just displays the window?
oh..hmm.. maybe I have this all backwards?
I believe I was 'only' running/clicking on the ERROR icons on the toolbox (left side.. bottom)
I have now clicked the DRC icon above that.. loaded my iteadStudio DRC file to check against..
(loaded,...apply... check)..
question: how 'important is the tRestrict layer? I mean it seems to 'pad' caps/resistors an awful lot..
Im not crowding 'too bad'.. but some of the tRestrict layers overlap.. if I turn this layer off.. I only have 2-3 errors..LOL
