(EAGLE) Exported .drl file same drill size problem
Hi.. I'm trying to export the .drl file but the factory said the drill are all the same size..
Trying to view the file and import it into 350CAM it says "tool numbers with no site: 1,2,3,4,5,6,7,8,9,10,11
The strange is... When I open the drillcfg.ulp file, choose mm it returns:
T01 0.50mm
T02 0.60mm
T03 0.61mm
T04 0.70mm
T05 0.80mm
T06 0.81mm
T07 1.00mm
T08 1.10mm
T09 1.12mm
T10 1.20mm
T11 3.20mm
But when it export the drl file and import into CAM350 it return the "no size" error.
Does anybody know now to solve it?
Thank you a lot.
What CAM job are you using? Have you tried the Sparkfun one?
