Hi Guys
Does anyone know if an Eagle library part exists for the following type of connector, and where can I find it?
I've hunted high and low with no success and have spent a fruitless weekend trying to create the part from scratch. I just can't manage to end up with a part that has two pins for each connector.
I want to use this part in conjunction with a standard pin header (three pins) to join together two boards that are at right angles to each other. Both boards are mechanically supported so joint rigidity is not a problem. This was the easiest (and cheapest) solution I could come up with - unless anyone has a better idea - please?
TIA
Bernie
