Hey gang...
Keeping with focus of trying to learn SoftCAD Eagle software...
I gave myself a goal of a board to 'design' using this software.
*Schematic
*PCB
*(all SMD)
I feel I have a 'decent' handle on the schematic editor....the library is a bit daunting still.. but I have edited parts & created my own custom parts and my own personal library as well
I laid out a basic/minimal Arduino circuit... with an on-board uSD socket.. (2 x vRegulators [3.3v & 5v] and a logic shifter)
named: uSDuino
not much more than that.
problem #1.)
I noticed the Atmega328 I made in my library was based off the chip the NANO uses? maybe not a TQFP 328P?
seemed to have a different pin out I noticed.. so went and updated/fixed this.. replaced symbol..re-connected all nets..etc
(only errors.. are warnings about having POWER PIN connected to 'XXX' pins..but its because I have names like GND & GND1..etc..read I can ignore these as electrically it is fine)
I was fairly confident about the schematic portion.... so I moved on to the PCB layout portion..
placed all my parts/components......
and started to route.. (both manually and after letting auto-route run).
I seem to be missing a big piece here.. LOL.. cause these 'airwires' are confusing as all 'heck'..
so maybe can explain them a bit? and how to route correctly? or tricks you have learned in your experiences dealing with routing and airwires?
I was under the impression that you click on route tool.. click on airwire.. and start 'routing'.. (drawing a line) to where that airwire leads to?
However.. when I click on a airwire..and start drawing my line(s).. I see the airwire 'end' destination seems to jump/move to the nearest component I routing by? what the?????!!!! lol
it also seems as if the airwires do not follow what son the schematic... multiple airwires going to same component?.
and lastly.. sometimes.. when i follow an airwire to route it.. I click on the final pad (or whatever) and big white "X" displays?
doesnt seem like a connection is being made? but I am following the airwire??
I have attached schematic and one of my attempts to learn better technique for routing.
feedback appreciated..
one special (questionable) area is the 2 voltage regulators.. it seems the airewires connect everything? all pins?
thanks
uSDuino_v1.1.zip (52.9 KB)
