Does anyone have an EagleCad component for these (TERMINAL BLOCK - 3-PIN 3.5MM)? I can't find them in the Adafruit library.
Datasheet: http://www.adafruit.com/datasheets/19963.pdf
Thanks!
Thanks!
Did you try the con-phoenix-350 library?
I did but the spacing is different on the pins.
So use Phoenix connectors then
ardilla:
You can always edit one of the Phoenix parts to match.
SparkFun-Connectors, M03LOCK_LONGPADS (M03), 1X03_LOCK_LONGPADS ? - Scotty
Thanks everyone for their prompt replies. Fortunately I've been led to a library that has that exact same part and also a nice silk screen too. I'll post a link to it here just in case anyone else is wondering: http://www.microbuilder.eu/Projects/EagleFootprintLibrary.aspx
