i'll post this code, but it may be very difficult for you to grasp.
looks like you want to coordinate the movements of various servos to do animation and have started writing a program to do that. but each loop performs just one animation.
i think you'll quickly realize, if you haven't already, that multiple servos may need to start at different times and before one servo has completed it's movement.
others have already suggested code to move a servo to a specified "target" position and to update all servos to move toward their target whether clockwise or ccw
in the code below uses "tables", arrays of C strutures (pg 114).
the feature [] table maintains a description of a servo, it's current position and target position. servoUpdate() is called to move it toward its target position if not at that position.
the 2nd table, movement [] describes a sequence of positions and the delay between steps (i.e. speed), allowing multiple movements at the same time, starting at different/overlapping times.
the goal is to provide the underlying support to specify a sequence of movements -- an animation -- by editing the sequence without getting bogged down with coding of specific servo functions
no doubt you'll have questions which i'm more than willing to answer if you'll take the time to understand this approach.
// animation
# include <Servo.h>
unsigned long msec;
char s [90];
// servo descriptions
enum { F_Jaw, F_LeftEye, F_RightEye };
struct Feature {
const byte PinServo;
int pos;
const char *desc;
int posTarg;
unsigned long msec0;
unsigned long msecDelay;
Servo servo;
feature [] = {
{ 9, 90, "jaw" },
{ 10, 0, "left-eye" },
{ 11, 0, "right-eye" },
int Nfeature = sizeof(feature)/sizeof(Feature);
unsigned long msecUpdt;
void servoUpdate ()
for (int n = 0; n < Nfeature; n++) {
int dPos = feature [n].posTarg - feature [n].pos;
#if 0
sprintf (s, " servoUpdate: %2d, dPos %6d, %6d %6d, %8lu %8lu msec %s",
n, dPos,
feature [n].posTarg, feature [n].pos,
feature [n].msec0, msec,
feature [n].desc);
Serial.println (s);
#endif
if (0 != dPos) {
if (msec - feature [n].msec0 < feature [n].msecDelay)
feature [n].msec0 += feature [n].msecDelay;
if (0 < dPos)
feature [n].pos++;
else if (0 > dPos)
feature [n].pos--;
feature [n].servo.write (feature [n].pos);
struct Movement {
unsigned long msec;
unsigned featureIdx;
int posTarg;
const char *desc;
movement [] {
{ 0, F_Jaw, 145, 15, "open jaw" },
{ 500, F_RightEye, 45, 15, "move right eye left" },
{ 500, F_LeftEye, 45, 15, "move left eye left" },
{ 1000, F_Jaw, 90, 15, "close jaw" },
{ 1200, F_RightEye, 0, 15, "move right eye right" },
{ 1200, F_LeftEye, 0, 15, "move left eye right" },
int Nmovement = sizeof(movement)/sizeof(Movement);
unsigned long msecMovement0;
int mIdx;
void loop ()
msec = millis ();
// update new feature movements
if (msec - msecMovement0 >= movement [mIdx].msec) {
Serial.println (movement [mIdx].desc);
int fIdx = movement [mIdx].featureIdx;
feature [fIdx].posTarg = movement [mIdx].posTarg;
feature [fIdx].msecDelay = movement [mIdx].msecDelay;
if (Nmovement <= ++mIdx) { // restart sequence
mIdx = 0;
msecMovement0 = msec;
Serial.println ("restart sequence");
// update servo positions
servoUpdate ();
void setup ()
Serial.begin (115200);
Serial.println ("animation");
feature [n].servo.attach (feature [n].PinServo);
feature [n].posTarg = feature [n].pos;
